Datasheet LTC3727A-1 (Analog Devices) - 2
DescriptionHigh Efficiency, 2-Phase Synchronous Step-Down Switching Regulators
Pages / Page32 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 341 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3727A-1
Input Supply Voltage (V TOP VIEW IN) ... 36V to –0.3V Top Side Driver Voltages RUN/SS1 1 28 PGOOD BOOST1, BOOST2 .. 42V to –0.3V SENSE1+ 2 27 TG1 SENSE1– 3 SW1 Switch Voltage (SW1, SW2) ... 36V to –5V 26 V 4 25 BOOST1 INTV OSENSE1 CC, EXTVCC, (BOOST1-SW1), PLLFLTR 5 24 VIN (BOOST2-SW2) ... 8.5V to –0.3V PLLIN 6 23 BG1 RUN/SS1, RUN/SS2, PGOOD .. 7V to –0.3V FCB 7 22 EXTVCC SENSE1+, SENSE2+, SENSE1–, I 8 21 TH1 INTVCC SENSE2– Voltages ... 14V to –0.3V SGND 9 20 PGND PLLIN, PLLFLTR, FCB Voltages .. INTVCC to –0.3V 3.3V 10 19 OUT BG2 ITH1, ITH2, VOSENSE1, VOSENSE2 Voltages ... 2.7V to –0.3V I 11 18 TH2 BOOST2 Peak Output Current <10μs (TG1, TG2, BG1, BG2) ...3A V 12 17 OSENSE2 SW2 INTV SENSE2– 13 TG2 CC Peak Output Current ... 50mA 16 Operating Temperature Range (Note 2).. –40°C to 85°C SENSE2+ 14 15 RUN/SS2 Junction Temperature (Note 3) ... 125°C G PACKAGE Storage Temperature Range ... –65°C to 150°C 28-LEAD PLASTIC SSOP T Lead Temperature (Soldering, 10 sec) .. 300°C JMAX = 125°C, θJA = 95°C/W
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3727AEG-1#PBF LTC3727AEG-1#TRPBF LTC3727AEG-1 28-Lead Plastic SSOP –40°C to 85°C LTC3727AIG-1#PBF LTC3727AIG-1#TRPBF LTC3727AIG-1 28-Lead Plastic SSOP –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3727AEG-1 LTC3727AEG-1#TR LTC3727AEG-1 28-Lead Plastic SSOP –40°C to 85°C LTC3727AIG-1 LTC3727AIG-1#TR LTC3727AIG-1 28-Lead Plastic SSOP –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V, VRUN/SS1, 2 = 5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
VOSENSE1, 2 Regulated Feedback Voltage (Note 4); ITH1, 2 Voltage = 1.2V l 0.792 0.800 0.808 V IVOSENSE1, 2 Feedback Current (Note 4) –5 –50 nA VREFLNREG Reference Voltage Line Regulation VIN = 3.6V to 30V (Note 4) 0.002 0.02 %/V VLOADREG Output Voltage Load Regulation (Note 4) Measured in Servo Loop; ΔITH Voltage = 1.2V to 0.7V l 0.1 0.5 % Measured in Servo Loop; ΔITH Voltage = 1.2V to 2.0V l –0.1 –0.5 % 3727a1fa 2
