Datasheet ADM3053 (Analog Devices) - 10
DescriptionSignal and Power Isolated CAN Transceiver with Integrated Isolated DC-to-DC Converter
Pages / Page18 / 10 — ADM3053. Data Sheet. 152. 330. IVER. 150. 325. EIV. 320. 148. RE O. VCC = …
RevisionE
File Format / SizePDF / 527 Kb
ADM3053. Data Sheet. 152. 330. IVER. 150. 325. EIV. 320. 148. RE O. VCC = 5V, VIO = 3.3V, RS = 0Ω. 315. 146. N T (ns). (ns) 310. OFF TO R xD. xD O xD 144
ADM3053 Data Sheet 152 330 IVER 150 325 EIV 320 148 RE O VCC = 5V, VIO = 3.3V, RS = 0Ω 315 146 N T (ns) (ns) 310 OFF TO R xD xD O xD 144
ADM3053 Data Sheet 152 330 ER IVER 150 325 EIV CE EC 320 148 RE O VCC = 5V, VIO = 3.3V, RS = 0Ω 315 146 N T (ns) (ns) 310 OFF TO R xD xD O xD 144 D 305 T Y Tx VCC = 5V, VIO = 3.3V, RS = 47kΩ 142 LAY 300 IVE,t onR ELA IVE,t offR 295 N DE 140 D IO ACT V INACT CC = 5V, VIO = 5V, RS = 0Ω 290 AT 138 TION GA 285 PAG A 136 OP 280 PRO PR V 134 275 CC = 5V, VIO = 5V, RS = 47kΩ –40 –15 10 35 60 85
106
–40 –15 10 35 60 85
109
TEMPERATURE (°C)
09293-
TEMPERATURE (°C)
09293- Figure 11. Propagation Delay from TxD On to Receiver Active vs. Figure 14. Propagation Delay from TxD Off to Receiver Inactive vs. Temperature Temperature
600 V 2.55 CC = 5V, VIO = 3.3V, RS = 47kΩ T, N IVER A IN CE 500 VCC = 5V, VIO = 5V, RS = 47kΩ 2.50 OM RE O D 400 GE N T 2.45 (ns) V xD O xD OLTA CC = 5V, VIO = 5V, RL = 60Ω T V 300 T V (V) 2.40 CC = 5V, VIO = 3.3V, RL = 60Ω U VCC = 5V, VIO = 5V, RL = 45Ω LAY V OD IVE,t onR TP VCC = 5V, VIO = 3.3V, RL = 45Ω N DE 200 2.35 IO ACT L OU AT TIA 100 EN PAG R 2.30 PRO IFFE D 0 2.25 –40 –15 10 35 60 85
107
–40 –15 10 35 60 85
110
TEMPERATURE (°C)
09293-
TEMPERATURE (°C)
09293- Figure 12. Propagation Delay from TxD On to Receiver Active vs. Figure 15. Differential Output Voltage Dominant vs. Temperature Temperature
250 2.55 ER T, N A VIO = 5V, TA = 25°C, RL = 60Ω EIV VCC = 5V, VIO = 3.3V, RS = 0Ω IN EC 2.50 200 OM D GE (ns) VCC = 5V, VIO = 5V, RS = 0Ω 2.45 OFF TO R xD 150 D OLTA (V) Y Tx T V 2.40 U V OD ELA IVE,t offR 100 TP D 2.35 INACT L OU TION TIA VIO = 5V, TA = 25°C, RL = 45Ω 50 GA EN A R 2.30 OP PR IFFE D 0 2.25 –40 –15 10 35 60 85
1 108
4.5 4.7 4.9 5.1 5.3 5.5
11
TEMPERATURE (°C)
09293-
SUPPLY VOLTAGE, VCC (V)
09293- Figure 13. Propagation Delay from TxD Off to Receiver Inactive vs. Figure 16. Differential Output Voltage Dominant vs. Supply Voltage, VCC Temperature Rev. E | Page 10 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
