Datasheet ADuM4122 (Analog Devices) - 18
Description | Single Gate, Adjustable Slew Rate, Isolated Gate Driver, 3 A Short-Circuit ( |
Pages / Page | 18 / 18 — ADuM4122. Data Sheet. OUTLINE DIMENSIONS. 6.05 5.85 5.65. 7.60 7.50 7.40. … |
File Format / Size | PDF / 641 Kb |
ADuM4122. Data Sheet. OUTLINE DIMENSIONS. 6.05 5.85 5.65. 7.60 7.50 7.40. 10.51 10.31. PIN 1. 10.11. MARK. 0.75. 2.45. 2.65. 0.50 45°. 2.35. 1.04
ADuM4122 Data Sheet OUTLINE DIMENSIONS 6.05 5.85 5.65 8 5 7.60 7.50 7.40 10.51 10.31 PIN 1 1 4 10.11 MARK 0.75 2.45 2.65 0.50 45° 2.35 1.04 2.50 0.25 2.25 BSC 8° 2.35 0° 0.30 0.20 SEATING 0.33 0.51 1.27 BSC PLANE 0.10 0.27 0.41 0.75 COPLANARITY 0.20 B 0.31 0.58 0.10 0.40 2014- 17- 09-
Figure 36. 8-Lead Standard Small Outline Package, with Increased Creepage [SOIC_IC] Wide Body (RI-8-1) Dimensions shown in millimeters
ORDERING GUIDE No. of Output Peak Minimum Output Temperature Package Model1 Channels Current (A) Voltage (V) Range Package Description Option
ADuM4122ARIZ 1 2 4.5 −40°C to +125°C 8-Lead SOIC_IC RI-8-1 ADuM4122ARIZ-RL 1 2 4.5 −40°C to +125°C 8-Lead SOIC_IC, RI-8-1 13” Tape and Reel ADuM4122BRIZ 1 2 7.5 −40°C to +125°C 8-Lead SOIC_IC RI-8-1 ADuM4122BRIZ-RL 1 2 7.5 −40°C to +125°C 8-Lead SOIC_IC, RI-8-1 13” Tape and Reel ADuM4122CRIZ 1 2 11.6 −40°C to +125°C 8-Lead SOIC_IC RI-8-1 ADuM4122CRIZ-RL 1 2 11.6 −40°C to +125°C 8-Lead SOIC_IC, RI-8-1 13” Tape and Reel EVAL-ADuM4122EBZ Evaluation Board 1 Z = RoHS Compliant Part.
©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D17024-0-2/19(0)
Rev. 0 | Page 18 of 18 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Specifications Regulatory Information Package Specifications Insulation and Safety Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Truth Table Typical Performance Characteristics Theory of Operation Applications Information PCB Layout Slew Rate Control Propagation Delay-Related Parameters Peak Current Rating Undervoltage Lockout Output Load Characteristics Power Dissipation Insulation Lifetime Typical Applications Outline Dimensions Ordering Guide
