Datasheet ADuM4138 (Analog Devices) - 24
Description | High Voltage, Isolated IGBT Gate Driver with Isolated Flyback Controller |
Pages / Page | 24 / 24 — ADuM4138. Data Sheet. OUTLINE DIMENSIONS. 10.45 10.15. 7.60 7.40. 10.55 … |
File Format / Size | PDF / 733 Kb |
ADuM4138. Data Sheet. OUTLINE DIMENSIONS. 10.45 10.15. 7.60 7.40. 10.55 10.05. PIN 1. INDICATOR. TOP VIEW. 0.40. 0.65 BSC. 0.25. 0.75 × 45°. 2.40
link to page 4
ADuM4138 Data Sheet OUTLINE DIMENSIONS 10.45 10.15 28 15 7.60 7.40 10.55 10.05 1 14 PIN 1 INDICATOR TOP VIEW 0.40 0.65 BSC 0.25 0.75 × 45° 0.25 2.40 2.65 2.25 SIDE VIEW END VIEW 2.35 0.32 8° 0.23 0° 0.25 0.25 BSC SEATING 0.10 (GAUGE PLANE) PLANE 1.40 1.27 REF A COPLANARITY 15- 0.40 4678 0.10 1-20 -00 G -0 K P 06
Figure 31. 28-Lead Standard Small Outline, Wide Body with Finer Pitch [SOIC_W_FP] (RN-28-1) Dimensions shown in millimeters
ORDERING GUIDE Package Model1, 2 Temperature Range Package Description Option
ADuM4138WBRNZ −40°C to +150°C 28-Lead Standard Small Outline, Wide Body with Finer Pitch [SOIC_W_FP] RN-28-1 ADuM4138WBRNZ-RL −40°C to +150°C 28-Lead Standard Small Outline, Wide Body, with Finer Pitch [SOIC_W_FP] RN-28-1 EVAL-ADuM4138EBZ Evaluation Board 1 Z = RoHS Compliant Part. 2 W = Qualified for Automotive Applications.
AUTOMOTIVE PRODUCTS
The ADuM4138W models are available with controlled manufacturing to support the quality and reliability requirements of automotive applications. Note that these automotive models may have specifications that differ from the commercial models; therefore, designers should review the Specifications section of this data sheet carefully. Only the automotive grade products shown are available for use in automotive applications. Contact your local Analog Devices account representative for specific product ordering information and to obtain the specific Automotive Reliability reports for these models.
©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D16036-0-12/18(0)
Rev. 0 | Page 24 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ELECTRICAL CHARACTERISTICS SPI TIMING SPECIFICATIONS SPI Timing Diagram PACKAGE CHARACTERISTICS REGULATORY INFORMATION (PENDING) INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10):2016-12 INSULATION CHARACTERISTICS (PENDING) RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PCB LAYOUT ISOLATED FLYBACK CONTROLLER SPI AND EEPROM OPERATION SPI Programming USER REGISTER MAP USER REGISTER BITS OFFSET_2[5:0] Bits GAIN_2[5:0] Bits OFFSET_1[5:0] Bits GAIN_1[5:0] Bits CONFIGURATION REGISTER BITS OT_FAULT_OP Bit OT_FAULT_SEL Bit OC_TIME_OP Bit OC_2LEV_OP Bits LOW_T_OP Bit OC_BLANK_OP Bit tBLANK[3:0] Bits ECC_OFF_OP Bit FLYBACK_V[3:0] Bits T_RAMP_OP Bit PWM_OSC Bit CONTROL REGISTER BITS ECC2_DBL_ERR Bit ECC2_SNG_ERR Bit ECC1_DBL_ERR Bit ECC1_SNG_ERR Bit PROG_BUSY Bit SIM_TRIM Bit PROPAGATION DELAY RELATED PARAMETERS PROTECTION FEATURES Primary Side UVLO Fault Reporting Overcurrent Detection High Speed, Two-Level, Turn Off Miller Clamp Desaturation Detection Thermal Shutdown Isolated Temperature Sensor POWER DISSIPATION INSULATION LIFETIME DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
