Datasheet HMC900LP5E (Analog Devices) - 7
Description50 MHz Dual Baseband Programmable Low Pass Filter
Pages / Page26 / 7 — HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Table …
HMC900LP5E. 50 MHz DUAL PROGRAMMABLE. LOW PASS FILTER with DRIVER. Table 3. Absolute Maximum Ratings. Outline Drawing
HMC900LP5E 50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Table 3 Absolute Maximum Ratings Outline Drawing
HMC900LP5E
v04.0811
50 MHz DUAL PROGRAMMABLE LOW PASS FILTER with DRIVER Table 3. Absolute Maximum Ratings
Nominal 5V supply to gND Reflow soldering VDDCal, VDDI, VDDQ, VDDBg, -0.3 to 5.5V Peak Temperature 260 °C DVDD Time at Peak Temperature 40 µs Common Mode Inputs Pins esD sensitivity (HBM) 1kV Class 1C -0.3 to 5.5V (CMI, CMQ) Input and Output Pins stresses above those listed under absolute Maximum Ratings may IIP, IIN, IQP, IQN, OIP, OIN, OQP, -0.3 to 5.5V cause permanent damage to the device. This is a stress rating only; OQN functional operation of the device at these or any other conditions Digital Pins above those indicated in the operational section of this specification seN, sDI, sCK, sDO, CalCK -0.3 to 5.5V is not implied. exposure to absolute maximum rating conditions for sDO min load impedance 1kΩ extended periods may affect device reliability. Operating Temperature Range -40 to +85 °C storage Temperature -65 to +125 °C eleCTROsTaTIC seNsITIVe DeVICe 3 Maximum Junction Temperature 125 °C OBseRVe HaNDlINg PReCaUTIONs Thermal Resistance (RTH) 10 °C/W (junction to ground paddle) g
Outline Drawing
IN s s e C O R l P a N Ig s D N NOTes: a [1] PaCKage BODY MaTeRIal: lOW sTRess INJeCTION MOlDeD PlasTIC B sIlICa aND sIlICON IMPRegNaTeD. [2] leaD aND gROUND PaDDle MaTeRIal: COPPeR allOY. e [3] leaD aND gROUND PaDDle PlaTINg: 100% MaTTe TIN. [4] DIMeNsIONs aRe IN INCHes [MIllIMeTeRs]. s [5] leaD sPaCINg TOleRaNCe Is NON-CUMUlaTIVe. a [6] PaD BURR leNgTH sHall Be 0.15mm MaX. PaD BURR HeIgHT sHall Be 0.25m MaX. [7] PaCKage WaRP sHall NOT eXCeeD 0.05mm [8] all gROUND leaDs aND gROUND PaDDle MUsT Be sOlDeReD TO PCB RF gOUND. [9] ReFeR TO HITTITe aPPlICaTION NOTe FOR sUggesTeD PCB laND IF / B PaTTeRN.
Table 4. Package Information
Part Number Package Body Material lead Finish Msl Rating [1] Package Marking [2] H900 HMC900lP5e RoHs-compliant low stress Injection Molded Plastic 100% matte sn Msl1 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Information furnish F e o d r b y pArnic alo e g , D d evi ecleis vie s rby eli, ea ve n d d to tbo e apl cc a ur c at e e ao n r d d releiars ble ,. p Ho le we a vesr, en c o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 7 0 Fax 0 • O : rd 9 e 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3
3 - 7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
