Datasheet BC847AT, BC847BT, BC847CT (Diodes)
| Manufacturer | Diodes |
| Description | NPN |
| Pages / Page | 6 / 1 — BC847AT, BT, CT. 45V NPN SMALL SIGNAL TRANSISTOR IN SOT523. Features. … |
| File Format / Size | PDF / 318 Kb |
BC847AT, BT, CT. 45V NPN SMALL SIGNAL TRANSISTOR IN SOT523. Features. Mechanical Data
BC847AT, BT, CT 45V NPN SMALL SIGNAL TRANSISTOR IN SOT523 Features Mechanical Data
BVCEO > 45V Case: SOT523 IC = 100mA Collector Current Case Material: Molded Plastic. ―Green‖ Molding Compound. Epitaxial Planar Die Construction UL Flammability Rating 94V-0 Ultra-Small Surface Mount Package Moisture Sensitivity: Level 1 per J-STD-020 Complementary PNP Type: MMBT3906T Terminals: Finish – Matte Tin Plated Leads. Solderable per
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
MIL-STD-202, Method 208
Halogen and Antimony Free. “Green” Device (Note 3)
Weight: 0.002 grams (Approximate)
Qualified to AEC-Q101 Standards for High Reliability C
SOT523
B E
Top View Device Symbol Pin-Out Top View
Ordering Information
(Note 4)
Part Number Compliance Marking Reel Size (inches) Tape Width (mm) Quantity per Reel
BC847AT-7-F AEC-Q101 1E 7 8 3,000 BC847BT-7-F AEC-Q101 1F 7 8 3,000 BC847CT-7-F AEC-Q101 1M 7 8 3,000 Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. 2. See http://www.diodes.com/quality/lead_free.html for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green‖ products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at http://www.diodes.com/products/packages.html.
Marking Information
XX = Product Type Marking Code YM = Date Code Marking K2 XX N YM M Y Y or Y = Year (ex: D = 2016) M or M = Month (ex: 9 = September) Date Code Key
Year 2015 2016 2017 2018 2019 2020 2021 2022 2023 2024 2025 Code
C D E F G H I J K L M
Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec Code
1 2 3 4 5 6 7 8 9 O N D BC847AT, BT, CT 1 of 6 September 2016 Document number: DS30274 Rev. 10 - 2
www.diodes.com
© Diodes Incorporated
