LTC4126-10 TYPICAL APPLICATIONWireless 10mA Li-Ion Battery Charger (4.2V) Tuned at 266kHz with Pushbutton Enabling R NTC BIAS 100k BAT LTC4126-10 NTC RESISTOR Li-Ion + V V IN SEL THERMALLY EN 4.2V RNTC 5V C2 AIR GAP V COUPLED CC R2 100µF (2mm TO 4mm) WITH BATTERY 732k D1 C1 CHRG R3 f OUT 1.2V LC_TANK = 266kHz 4.7µF 66.5k ACIN 2.2µF CTX1 33nF L L TX RX CTX2 2.7µH 8µH STAT1 V+ 100nF f MOD DRIVE = 216kHz C STAT2 DIGITAL I/O RX LTC6992 68nF ACPR M1 SET OUT GND PBEN Si2312CDS R1 DIV PUSHBUTTON 4126-10 TA03 232k GND CTX1: TDK C2012COG1H333J125AA CTX2: TDK C3216COG1H104J160AA LTX: SUNLORD MQQTC202030S2R7 CRX: AVX0603YC683JAT2A LRX: SUNLORD MQQRC060630S8R0 RNTC: VISHAY NTCS0402E3104*HT M1: VISHAY Si2312CDS-T1-GE3 D1: ROHM SEMICONDUCTOR STL-311UTT86 RELATED PARTS PART NUMBER DESCRIPTIONCOMMENTS LTC4120 400mA Wireless Power Receiver Buck Battery Wireless 1 to 2 Cell Li-Ion Charger, 400mA Charge Current, Dynamic Harmonization Charger Control, Wide Input Range: 12.5V to 40V, 16-Lead 3mm × 3mm QFN Package LTC4123 Low Power Wireless Charger for Hearing Aids Wireless Single NiMH Charger, Integrated Rectifier with Overvoltage Limit, 25mA Charge Current, Zn-Air Detect, Temperature Compensated Charge Voltage, 6-Lead 2mm × 2mm DFN Package LTC4125 5W Auto Resonant Wireless Power Transmitter Monolithic Auto Resonant Full Bridge Driver. Transmit Power Automatically Adjusts to Receiver Load, Foreign Object Detection, Wide Operating Switching Frequency Range: 50kHz to 250kHz, Input Voltage Range 3V to 5.5V, 20-Lead 4mm × 5mm QFN Package LTC4126 7.5mA Wireless Li-Ion Charger with 1.2V Step- Wireless 1-Cell Li-Ion 7.5mA Battery Charger, High Efficiency Multi-Mode Charge Pump Down DC/DC Converter DC/DC Converter with Regulated 1.2V Output at Up to 60mA, 4.2V or 4.35V Charge Voltage, Thermally Enhanced 12-Lead 2mm × 2mm LQFN Package LTC4070 Li-Ion/Polymer Shunt Battery Charger System Li-Ion/Polymer Shunt Battery Charger, Low Operating Current (450nA), 50mA Internal Shunt Current, Pin Selectable Float Voltages (4.0V, 4.1V, 4.2V), 8-Lead 2mm × 3mm DFN and MSOP Packages LTC4071 Li-Ion/Polymer Shunt Battery Charger System Charger Plus Pack Protection in One IC, Low Operating Current (550nA), 50mA Internal with Low Battery Disconnect Shunt Current, Pin Selectable Float Voltages (4.0V, 4.1V, 4.2V), 8-Lead 2mm × 3mm DFN and MSOP Packages LTC6990 TimerBlox: Voltage Controlled Silicon Oscillator Fixed-Frequency or Voltage-Controlled Operation, Frequency Range of 488Hz to 2MHz, Low-Profile SOT-23 and 2mm × 3mm DFN Packages LTC6992 TimerBlox: Voltage Controlled Pulse-Width Pulse Width Modulation by 0V to 1V Analog Input, Frequency Range of 3.81Hz to 1MHz, Modulator (PWM) Low-Profile SOT-23 and 2mm × 3mm DFN Packages Rev. 0 22 7/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2019 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
