Datasheet VCNL3040 (Vishay) - 4
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, IRED, and I²C Interface
Pages / Page17 / 4 — VCNL3040. I2C BUS TIMING CHARACTERISTICS. STANDARD MODE. FAST MODE. …
File Format / SizePDF / 258 Kb
VCNL3040. I2C BUS TIMING CHARACTERISTICS. STANDARD MODE. FAST MODE. PARAMETER. SYMBOL. UNIT. MIN. MAX
VCNL3040 I2C BUS TIMING CHARACTERISTICS STANDARD MODE FAST MODE PARAMETER SYMBOL UNIT MIN MAX
VCNL3040
(Tamb = 25 °C, unless otherwise specified)
STANDARD MODE FAST MODE PARAMETER SYMBOL UNIT MIN. MAX. MIN. MAX.
Clock frequency f(SMBCLK) 10 100 10 400 kHz Bus free time between start and stop condition t(BUF) 4.7 - 1.3 - μs Hold time after (repeated) start condition; t after this period, the first clock is generated (HDSTA) 4.0 - 0.6 - μs Repeated start condition setup time t(SUSTA) 4.7 - 0.6 - μs Stop condition setup time t(SUSTO) 4.0 - 0.6 - μs Data hold time t(HDDAT) 0 3450 0 900 ns Data setup time t(SUDAT) 250 - 100 - ns I2C clock (SCK) low period t(LOW) 4.7 - 1.3 - μs I2C clock (SCK) high period t(HIGH) 4.0 - 0.6 - μs Clock / data fall time t(F) - 300 - 300 ns Clock / data rise time t(R) - 1000 - 300 ns t t t (LOW) (R) (F) VIH I2C BUS CLOCK VIL (SCL) t t t (HDSTA) (HIGH) (SUSTA) t(SUSTO) t(BUF) t t (HDDAT) (SUDAT) I2C BUS VIH DATA (SDA) VIL { { { { P S S P Stop condition Start condition Start Stop t(LOSEXT) SCL SDA ACK ACK t t t (LOWMEXT) (LOWMEXT) (LOWMEXT) I2C BUS CLOCK (SCL) I2C BUS DATA (SDA) Fig. 1 - I2C Bus Timing Diagram Rev. 1.2, 08-Jul-2019
4
Document Number: 84917 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
