Datasheet IR3826A (Infineon) - 53
Manufacturer | Infineon |
Description | OptiMOS™ IPOL 16 A single-voltage synchronous buck regulator |
Pages / Page | 53 / 53 — HermosaSFET6 IR3826A. RevisionHistory. Revision:2019-07-03,Rev.2.2. … |
Revision | 02_02 |
File Format / Size | PDF / 2.2 Mb |
HermosaSFET6 IR3826A. RevisionHistory. Revision:2019-07-03,Rev.2.2. Trademarks. WeListentoYourComments. erratum@infineon.com
HermosaSFET6 IR3826A RevisionHistory
IR3826A
Previous Revision Revision Date Subjects (major changes since last revision) 2.0 2018-04-17 Release of final version 2.1 2019-06-28 Trademark edits 2.2 Clarify the Bootstrap diode voltage spec by adding spec at Tj = 0degC ~ 125degC. 2019-07-03 Clarifications added to Vcc dropout test conditions and note 5. Update Figure4, Figure 20, and Icc curve in Figure 7,
Trademarks
Allreferencedproductorservicenamesandtrademarksarethepropertyoftheirrespectiveowners.
Anyinformationwithinthisdocumentthatyoufeeliswrong,unclearormissingatall?Yourfeedbackwillhelpustocontinuously improvethequalityofthisdocument.Pleasesendyourproposal(includingareferencetothisdocument)to:
erratum@infineon.com Publishedby InfineonTechnologiesAG 81726München,Germany ©2019InfineonTechnologiesAG AllRightsReserved. LegalDisclaimer
Theinformationgiveninthisdocumentshallinnoeventberegardedasaguaranteeofconditionsorcharacteristics (“Beschaffenheitsgarantie”). Withrespecttoanyexamples,hintsoranytypicalvaluesstatedhereinand/oranyinformationregardingtheapplicationofthe product,InfineonTechnologiesherebydisclaimsanyandallwarrantiesandliabilitiesofanykind,includingwithoutlimitation warrantiesofnon-infringementofintellectualpropertyrightsofanythirdparty. Inaddition,anyinformationgiveninthisdocumentissubjecttocustomer’scompliancewithitsobligationsstatedinthis documentandanyapplicablelegalrequirements,normsandstandardsconcerningcustomer’sproductsandanyuseofthe productofInfineonTechnologiesincustomer’sapplications. Thedatacontainedinthisdocumentisexclusivelyintendedfortechnicallytrainedstaff.Itistheresponsibilityofcustomer’s technicaldepartmentstoevaluatethesuitabilityoftheproductfortheintendedapplicationandthecompletenessoftheproduct informationgiveninthisdocumentwithrespecttosuchapplication.
Information
Forfurtherinformationontechnology,deliverytermsandconditionsandpricespleasecontactyournearestInfineon TechnologiesOffice(
www.infineon.com
Warnings
Duetotechnicalrequirements,componentsmaycontaindangeroussubstances.Forinformationonthetypesinquestion, pleasecontactthenearestInfineonTechnologiesOffice. TheInfineonTechnologiescomponentdescribedinthisDataSheetmaybeusedinlife-supportdevicesorsystemsand/or automotive,aviationandaerospaceapplicationsorsystemsonlywiththeexpresswrittenapprovalofInfineonTechnologies,ifa failureofsuchcomponentscanreasonablybeexpectedtocausethefailureofthatlife-support,automotive,aviationand aerospacedeviceorsystemortoaffectthesafetyoreffectivenessofthatdeviceorsystem.Lifesupportdevicesorsystemsare intendedtobeimplantedinthehumanbodyortosupportand/ormaintainandsustainand/orprotecthumanlife.Iftheyfail,itis reasonabletoassumethatthehealthoftheuserorotherpersonsmaybeendangered. 53 Rev.2.2,2019-07-03 Document Outline Revision History Trademarks Disclaimer
