Datasheet PI4ULS5V108Q (Diodes) - 4
| Manufacturer | Diodes |
| Description | Automotive Qualified 8-BIT Bi-Directional Level Shifter for Open-Drain and Push-Pull Application |
| Pages / Page | 11 / 4 — PI4ULS5V108Q. DC Electrical Characteristics Cont. Parameter. Description. … |
PI4ULS5V108Q. DC Electrical Characteristics Cont. Parameter. Description. Test Conditions(1). Min. Typ.(2). Max. Unit. Notes:
PI4ULS5V108Q DC Electrical Characteristics Cont. Parameter Description Test Conditions(1) Min Typ.(2) Max Unit
VREFA = 3.3 V; 8 Ω VI = 0V; IO = 64mA; VREFB ,VEN connect to VREFA = 1.8 V; 9 Ω 5 V through 200k Ω VREFA = 1.0 V; 10 Ω VI = 0V; IO = 32mA VREFA = 1.8 V; 10 Ω VREFB ,VEN connect to 5 V through 200k Ω VREFA = 2.5 V; 15 Ω VI = 1.8V; IO = 15mA VREFB ,VEN connect to VREFA = 3.3 V; 9 Ω Ron ON-state resistance 5V through 200k Ω VI = 1.0V; IO = 10mA VREFB ,VEN connect to VREFA = 1.8 V; 18 Ω 3.3V through 200k Ω VI = 0V; IO = 10mA VREFB ,VEN connect to VREFA = 1.0 V; 20 Ω 3.3V through 200k Ω VI = 0V; IO = 10mA VREFB ,VEN connect to VREFA = 1.0 V; 30 Ω 1.8V through 200k Ω
Notes:
1) All typical values are at TA = 25 °C. 2) Measured by the voltage drop between the A and B pins at the indicated current through the switch. ON-state resistance is determined by the lowest voltage of the two terminals. PI4ULS5V108Q
www.diodes.com
May 2019 Document Number DS41647 Rev 2-2 4 © Diodes Incorporated
