User Manual WSEN-PADS / 2511020213301 (Wurth Elektronik) - 4
| Manufacturer | Wurth Elektronik |
| Description | Absolute Pressure Sensor |
| Pages / Page | 87 / 4 — Contents. Introduction. Sensor specifications. Pinning information. … |
| File Format / Size | PDF / 9.2 Mb |
Contents. Introduction. Sensor specifications. Pinning information. Digital interface. Application circuit. Quick start guide
link to page 8 link to page 8 link to page 8 link to page 8 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 13 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 16 link to page 14 link to page 14 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 18 link to page 19 link to page 21 link to page 22 link to page 24 link to page 24 link to page 25 link to page 25 link to page 25 link to page 27 link to page 28 link to page 29
Contents 1 Introduction 7
1.1 Application . 7 1.2 Key features . 7 1.3 Ordering information . 7 1.4 Block diagram . 8 1.5 Operational functionality . 8 1.5.1 MEMS Cell . 8 1.5.2 ASIC . 8 1.5.3 Calibration . 8 1.5.4 Digital filtering . 9 1.5.5 FIFO memory . 9 1.6 Filtering chain and data path . 9
2 Sensor specifications 10
2.1 General information . 10 2.2 Absolute maximum ratings . 10 2.3 Pressure sensor specification . 11 2.4 Temperature sensor specification . 11 2.5 Electrical specifications . 12
3 Pinning information 13
3.1 Pin configuration . 13 3.2 Pin description . 13
4 Digital interface 14
4.1 General characteristics . 14 4.2 SDA and SCL logic levels . 15 4.3 Communication phase . 15 4.3.1 Idle state . 15 4.3.2 START(S) and STOP(P) condition . 15 4.3.3 Data validity . 16 4.3.4 Byte format . 16 4.3.5 Acknowledge(ACK) and No-Acknowledge(NACK) . 16 4.3.6 Slave address for the sensor . 17 4.3.7 Read/Write operation . 18 4.4 I2C timing parameters . 20
5 Application circuit 21 6 Quick start guide 23
6.1 Power-up sequence . 23 6.2 Communication with host controller . 24 6.3 Reboot . 24 6.4 Software reset . 24 6.5 Sensor operation: single conversion mode . 26 6.6 Sensor operation: continuous mode . 27 6.7 Power-off sequence . 28 Absolute pressure sensor, Part Nr. 2511020213301 User manual version 1.0 © June 2019 www.we-online.com/sensors 3 Document Outline Introduction Application Key features Ordering information Block diagram Operational functionality MEMS Cell ASIC Calibration Digital filtering FIFO memory Filtering chain and data path Sensor specifications General information Absolute maximum ratings Pressure sensor specification Temperature sensor specification Electrical specifications Pinning information Pin configuration Pin description Digital interface General characteristics [fig:pinout]SDA and [fig:pinout]SCL logic levels Communication phase Idle state START(S) and STOP(P) condition Data validity Byte format Acknowledge(ACK) and No-Acknowledge(NACK) Slave address for the sensor Read/Write operation I2C timing parameters Application circuit Quick start guide Power-up sequence Communication with host controller Reboot Software reset Sensor operation: single conversion mode Sensor operation: continuous mode Power-off sequence Modes of operation Power-down mode Single conversion mode Continuous mode Additional configurations Low-power or low-noise configuration Enabling additional low-pass filter Reading output data Reading pressure values Reading temperature values Status register for reading the data FIFO buffer Bypass mode FIFO mode Continuous mode Bypass-to-FIFO mode Bypass-to-continuous mode Continuous-to-FIFO mode FIFO status monitoring and control User-defined FIFO threshold Reading data from FIFO buffer Interrupt functionality Interrupt generation on pressure data-ready Interrupt generation based on pressure threshold Interrupt latching FIFO status based interrupt events Routing interrupt events to the [fig:pinout]INT pin Register map Register description INT_CFG (0x0B) THR_P_L (0x0C) THR_P_H (0x0D) INTERFACE_CTRL (0x0E) DEVICE_ID (0x0F) CTRL_1 (0x10) CTRL_2 (0x11) CTRL_3 (0x12) FIFO_CTRL (0x13) FIFO_WTM (0x14) REF_P_L (0x15) REF_P_H (0x16) OPC_L (0x18) OPC_H (0x19) INT_SOURCE (0x24) FIFO_STATUS_1 (0x25) FIFO_STATUS_2 (0x26) STATUS (0x27) DATA_P_XL (0x28) DATA_P_L (0x29) DATA_P_H (0x2A) DATA_T_L (0x2B) DATA_T_H (0x2C) FIFO_DATA_P_XL (0x78) FIFO_DATA_P_L (0x79) FIFO_DATA_P_H (0x7A) FIFO_DATA_T_L (0x7B) FIFO_DATA_T_H (0x7A) Physical dimensions Sensor drawing Footprint Manufacturing information Moisture sensitivity level Soldering Reflow soldering Cleaning and washing Potting and coating Storage conditions Handling Important notes General customer responsibility Customer responsibility related to specific, in particular safety-relevant applications Best care and attention Customer support for product specifications Product improvements Product life cycle Property rights General terms and conditions Legal notice Exclusion of liability Suitability in customer applications Usage restriction License agreement for Würth Elektronik eiSos GmbH & Co. KG sensor product software and source code Limited license Usage and obligations Ownership Disclaimer of warranty Limitation of liability Applicable law and jurisdiction Severability clause Miscellaneous
