Datasheet TCA0372, TCA0372B, NCV0372B (ON Semiconductor) - 2
ManufacturerON Semiconductor
Description1.0 A Output Current, Dual Power Operational Amplifiers
Pages / Page10 / 2 — TCA0372, TCA0372B, NCV0372B. MAXIMUM RATINGS. Rating. Symbol. Value. …
File Format / SizePDF / 187 Kb
TCA0372, TCA0372B, NCV0372B. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. http://onsemi.com
TCA0372, TCA0372B, NCV0372B MAXIMUM RATINGS Rating Symbol Value Unit http://onsemi.com
link to page 2 link to page 2 link to page 2
Supply Voltage (from VCC to VEE) VS 40 V Input Differential Voltage Range VIDR Note 1 V Input Voltage Range VIR Note 1 V Junction Temperature (Note 2) TJ +150 °C Operating Temperature Range TA −40 to +125 °C Storage Temperature Range Tstg −55 to +150 °C DC Output Current IO 1.0 A Peak Output Current (Nonrepetitive) I(max) 1.5 A Thermal Resistance, Junction−to−Air RqJA °C/W Case 626 137 Case 648 72 Case 751G 80 Thermal Resistance, Junction−to−Case RqJC °C/W Case 626 23 Case 648 10 Case 751G 12 Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. 1. Either or both input voltages should not exceed the magnitude of VCC or VEE. 2. Power dissipation must be considered to ensure maximum junction temperature (TJ) is not exceeded.
http://onsemi.com 2
