Datasheet PAM8904Q (Diodes) - 8
| Manufacturer | Diodes |
| Description | Automotive 18VPP Output Peizo Sounder Driver |
| Pages / Page | 11 / 8 — PAM8904Q. Application Information. Output Configuration. Differential … |
| File Format / Size | PDF / 407 Kb |
PAM8904Q. Application Information. Output Configuration. Differential Output Typical Application Circuit
PAM8904Q Application Information
(Cont.)
The PAM8904Q is able to be configured either in a differential or a single ended configuration.
C1 = 0.1uF C2 = 0.1uF CIN = 0.1uF VOUT Charge Pump V Mode:1x, 2x, 3x or Shutdown IN COUT = 0.1uF CPM1 CPM Controller Oscillator 2 Protection Detector Short Circuit/ OTP VO1 Level Shift DIN GND Piezo Sounder/ Speaker VO2
Single Ended Output Typical Application Circuit
C1 = 0.1uF C2 = 0.1uF CIN = 0.1uF VOUT Charge Pump V Mode:1x, 2x, 3x or Shutdown IN COUT = 0.1uF CPM1 CPM Controller Oscillator 2 Protection Detector Short Circuit/ OTP VO1 Level Shift DIN GND Piezo Sounder/ Speaker VO2 When using the PAM8904Q with a single ended output, the VO2 pin should be left open circuit. PAM8904Q 8 of 11 November 2016 Document number: DS38977 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
