Datasheet CCE4503 (Dialog Semiconductor) - 7
| Manufacturer | Dialog Semiconductor |
| Description | IO-Link Device |
| Pages / Page | 16 / 7 — CCE4503. IO-Link Device IC. 3.2. Recommended Operating Conditions. Table … |
| File Format / Size | PDF / 619 Kb |
CCE4503. IO-Link Device IC. 3.2. Recommended Operating Conditions. Table 4: Recommended Operating Conditions. Parameter. Conditions
CCE4503 IO-Link Device IC 3.2 Recommended Operating Conditions Table 4: Recommended Operating Conditions Parameter Conditions Pin Name Min Typ Max Unit
Main Supply Voltage 7, 9 V
L+
7 36 V Supply Voltage Ripple F
ripple
= DC … 100kHz 9 ∆V
L+
1 V VL+ > 12 V Voltage CQ Receiver mode 8 V
CQ_MAX
VL- VL+ V Logic Level Supply External Supply 1 VDD 3 5.5 V Voltage LDO Output Current 3.3V LDO or 5V LDO, 1 I
VDD
20 mA V
L+
≤ 24V ILIM External Resistor To L- 6 R
ILIM
0 100 kΩ LDO External To L- 1 C
LDO
0.8 1 1.2 µF Capacitor
3.3 Electrical Characteristics Table 5: Input / Output CQ Parameter Conditions Pin Name Min Typ Max Unit
Output voltage low active pull down, 8 V
OL
0 1.5 V level I
OL
=-200mA Output voltage high active pull up, 8 V
OH
VL+ - VL+ V level I
OH
=+200mA 1.5 Leakage current input enabled 8 I
leak
-2 2 µA 0 ≤ VCQ ≤ VL+ - 0.1 V Maximum Permanent Current of CQ 8 I
CQmax
-250 250 mA Output Current channel Output source current RILIM = 0 or hZ 8 I
limP
300 350 400 mA limit RILIM = 100 kΩ 35 50 70 Output sink current RILIM = 0 or hZ 8 I
limN
-400 -350 -300 mA limit RILIM = 100 kΩ -70 -50 -35 Load capacitance 8 C
L
5 nF Inductive load 8 L
Load
1.5 H Output rise/fall time Open load, RILIM = 0 8 t
r,f
869 ns (20% to 80%) or hZ Switch On Time 8 t
DLY_LH
4 µs Switch Off Time 8 t
DLY_HL
4 µs Short circuit detection 8 T
SHORT
300 µs time Short circuit disable 8 T
SHORT_DIS
µs time
Datasheet Revision 2.0 20.02.2020
CFR0011-120-00 7 of 16 © 2020 Dialog Semiconductor
