Datasheet GP2Y0A41SK0F (Sharp) - 9
ManufacturerSharp
DescriptionDistance Measuring Sensor Unit Measuring distance: 4 to 30 cm Analog output type
Pages / Page9 / 9 — GP2Y0A41SK0F. Important Notices
GP2Y0A41SK0F Important Notices
· The circuit application examples in this publication are provided with equipment that requires higher reliability such as: to explain representative applications of SHARP devices and are --- Transportation control and safety equipment (i.e., not intended to guarantee any circuit design or license any aircraft, trains, automobiles, etc.) intellectual property rights. SHARP takes no responsibility for --- Traffic signals any problems related to any intellectual property right of a third --- Gas leakage sensor breakers party resulting from the use of SHARP's devices. --- Alarm equipment --- Various safety devices, etc. · Contact SHARP in order to obtain the latest device specification (iii) SHARP devices shall not be used for or in connection with sheets before using any SHARP device. SHARP reserves the equipment that requires an extremely high level of reliability and right to make changes in the specifications, characteristics, data, safety such as: materials, structure, and other contents described herein at any --- Space applications time without notice in order to improve design or reliability. --- Telecommunication equipment [trunk lines] Manufacturing locations are also subject to change without --- Nuclear power control equipment notice. --- Medical and other life support equipment (e.g., scuba). · Observe the following points when using any devices in this publication. SHARP takes no responsibility for damage caused · If the SHARP devices listed in this publication fall within the by improper use of the devices which does not meet the scope of strategic products described in the Foreign Exchange conditions and absolute maximum ratings to be used specified in and Foreign Trade Law of Japan, it is necessary to obtain the relevant specification sheet nor meet the following approval to export such SHARP devices. conditions: (i) The devices in this publication are designed for use in general · This publication is the proprietary product of SHARP and is electronic equipment designs such as: copyrighted, with all rights reserved. Under the copyright laws, --- Personal computers no part of this publication may be reproduced or transmitted in --- Office automation equipment any form or by any means, electronic or mechanical, for any --- Telecommunication equipment [terminal] purpose, in whole or in part, without the express written --- Test and measurement equipment permission of SHARP. Express written permission is also --- Industrial control required before any use of this publication may be made by a --- Audio visual equipment third party. --- Consumer electronics (ii) Measures such as fail-safe function and redundant design · Contact and consult with a SHARP representative if there are should be taken to ensure reliability and safety when SHARP any questions about the contents of this publication. devices are used for or in connection Sheet No.: OP13008EN 9
