Datasheet ADCMP394, ADCMP395, ADCMP396 (Analog Devices)
DescriptionDual Comparator with Accurate Reference Output
Pages / Page18 / 1 — Single/Dual/Quad Comparators with. Accurate Reference Output. Data Sheet. …
RevisionB
File Format / SizePDF / 412 Kb
Single/Dual/Quad Comparators with. Accurate Reference Output. Data Sheet. ADCMP394. /ADCMP395. /ADCMP396. FEATURES
Datasheet ADCMP394, ADCMP395, ADCMP396 Analog Devices, Revision: B
Single/Dual/Quad Comparators with Accurate Reference Output Data Sheet ADCMP394 /ADCMP395 /ADCMP396 FEATURES FUNCTIONAL BLOCK DIAGRAMS High accuracy reference output voltage: 1 V ± 0.9% VCC Single-supply voltage operation: 2.3 V to 5.5 V ADCMP394 Rail-to-rail common-mode input voltage range REF REF Low input offset voltage across VCMR: 1 mV typical Guarantees comparator output logic low from V IN+ CC = 0.9 V to OUT IN– undervoltage lockout (UVLO)
001
Operating temperature range: −40°C to +125°C GND
12209-
Package types:
Figure 1.
8-lead, narrow body SOIC (ADCMP394) VCC 10-lead MSOP (ADCMP395) 16-lead, narrow body SOIC (ADCMP396) ADCMP395 REF REF APPLICATIONS INA+ Battery management/monitoring OUTA INA– Power supply detection INB+ OUTB Window comparators INB–
202
Threshold detectors/discriminators GND
12209-
Microprocessor systems
Figure 2.
GENERAL DESCRIPTION VCC
The ADCMP394/ADCMP395/ADCMP396 are single/dual/quad
ADCMP396
rail-to-rail input, low power comparator ideal for use in general-
REF REF
purpose applications. These comparators operate from a supply
INA+ OUTA
voltage of 2.3 V to 5.5 V and draw a minimal amount of
INA–
current. The single ADCMP394 consumes only 33.9 μA of
INB+ OUTB INB–
supply current. The dual ADCMP395 and quad ADCMP396
INC+
consumes 37.2 μA and 41.6 μA of supply current respectively.
OUTC INC–
The low voltage and low current operation of these devices
IND+ OUTD
makes it ideal for battery-powered systems.
IND–
03 2 The comparators features a common-mode input voltage range 09-
GND
122 of 200 mV beyond rails, an offset voltage of 1 mV typical across Figure 3. the full common-mode range, and a UVLO monitor. In addition, the design of the comparator allows a defined output state upon power-up. The comparator generates a logic low output if the supply voltage is less than the UVLO threshold. The ADCMP394/ADCMP395/ADCMP396 incorporates a 1 V ± 0.9% buffered reference voltage. The reference voltage output can directly connect to the comparator input to serve as the trip value for precise monitoring and detection of positive voltage. It can also act as an offset when monitoring the negative voltage. The ADCMP394 and ADCMP396 are available in 8-pin and 16- lead, narrow body SOIC package, respectively. The ADCMP395 is available in a 10-lead MSOP package. The comparators are specified to operate over the −40°C to +125°C extended temperature range.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENT REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
