Datasheet ADCMP361 (Analog Devices) - 9
| Description | Single 0.275% Comparator and Reference with Dual Polarity Outputs |
| Pages / Page | 12 / 9 — Data Sheet. ADCMP361. 1000. TA = 85°C. VDD = 5V. TA = +25°C. TA = –40°C. … |
| Revision | B |
| File Format / Size | PDF / 296 Kb |
Data Sheet. ADCMP361. 1000. TA = 85°C. VDD = 5V. TA = +25°C. TA = –40°C. VDD = 5.0V. DD = 3.3V. VDD = 2.5V. mA). DD = 1.8V. 100. OLTA. A = +85°C
Data Sheet ADCMP361 1000 80 TA = 85°C VDD = 5V TA = +25°C TA = –40°C ) VDD = 5.0V V 70 V m DD = 3.3V ( VDD = 2.5V GE V mA) 60 DD = 1.8V ( 100 NT OLTA 50 V T T A = +85°C A = +125°C CURRE TION T 40 A R RCUI TU 30 A 10 -CI T S RT U 20 HO TP S OU 10 1 0 0.001 0.01 0.1 1 10
021
0 2 4
022
OUTPUT SINK CURRENT (mA) OUTPUT VOLTAGE (V)
06496- 06496- Figure 23. Output Saturation Voltage vs. Output Sink Current Figure 26. Short-Circuit Current vs. Output Voltage
70 10 TA = 25°C V V DD = 5V DD = 5.0V 60 A) T n A = +125°C mA) ( ( 1 50 NT NT TA = +85°C VDD = 3.3V 40 T CURRE A = +25°C CURRE E T 0.1 V 30 DD = 2.5V TA = –40°C RCUI AKAG E -CI L RT 20 VDD = 1.8V UT P 0.01 HO S UT O 10 0 0.001 0 2 4
023
0 1 2 3 4 5
024
OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
06496- 06496- Figure 24. Short-Circuit Current vs. Output Voltage Figure 27. Output Leakage Current vs. Output Voltage
60 100 T LH NONINV A = 25°C VDD = 5V LH INV CL = 20pF HL NONINV T 50 A = 25°C HL INV s) s) 10 µ µ ( ( 40 S AY E L IM RISE T N DE L 30 1 IO AL AT AG P 20 AND F E RO S P RI 0.1 10 FALL 0 0.01 0 20 40 60 80 100
025
0.1 1 10 100 1000
027
INPUT OVERDRIVE (mV) OUTPUT PULL-UP RESISTOR (kΩ)
06496- 06496- Figure 25. Propagation Delay vs. Input Overdrive Figure 28. Rise and Fall Times vs. Output Pull-Up Resistor Rev. B | Page 9 of 12 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Application Information Comparators and Internal Reference Power Supply Inputs Outputs Adding Hysteresis Outline Dimensions Ordering Guide Automative Products
