Datasheet ADSP-21065L-EP (Analog Devices) - 8
DescriptionSHARC DSP Microcomputer
Pages / Page14 / 8 — ADSP-21065L-EP. Enhanced Product. SPECIFICATIONS. OPERATING CONDITIONS. …
File Format / SizePDF / 360 Kb
ADSP-21065L-EP. Enhanced Product. SPECIFICATIONS. OPERATING CONDITIONS. Parameter. Description. Min. Max. Unit. ABSOLUTE MAXIMUM RATINGS
ADSP-21065L-EP Enhanced Product SPECIFICATIONS OPERATING CONDITIONS Parameter Description Min Max Unit ABSOLUTE MAXIMUM RATINGS
link to page 8
Note that component specifications are subject to change without notice. See Environmental Conditions for information on thermal specifications.
VDD Supply Voltage 3.13 3.60 V TCASE Case Operating Temperature –55 +110 C VIH High Level Input Voltage @ VDD = Max 2.0 VDD + 0.5 V VIL1 Low Level Input Voltage @ VDD = Max1 –0.5 0.8 V VIL2 Low Level Input Voltage @ VDD = Min2 –0.5 0.7 V 1 Applies to input and bidirectional pins: DATA31–0, ADDR23–0, BSEL, RD, WR, SW, ACK, SBTS, IRQ2–0, FLAG11–0, HGB, CS, DMAR1, DMAR2, BR2–1, ID2–0, RPBA, CPA, TFS0, TFS1, RFS0, RFS1, BMS, TMS, TDI, TCK, HBR, DR0A, DR1A, DR0B, DR1B, TCLK0, TCLK1, RCLK0, RCLK1, RESET, TRST, PWM_EVENT0, PWM_EVENT1, RAS, CAS, SDWE, SDCKE. 2 Applies to input pin CLKIN.
Stresses at or above those listed in Table 3 may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating condi- tions for extended periods may affect product reliability.
Table 3. Absolute Maximum Ratings Parameter Rating
Supply Voltage (VDD) –0.3 V to +4.6 V Input Voltage –0.5 V to VDD + 0.5 V Output Voltage Swing –0.5 V to VDD + 0.5 V Load Capacitance 200 pF Storage Temperature Range –65C to +150C Lead Temperature (5 seconds) 280C Junction Temperature Under Bias 150C
ESD CAUTION ESD (electrostatic discharge) sensitive device.
Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality. Rev. B | Page 8 of 14 | September 2017 Document Outline Summary Enhanced Product (EP) Features Features Table of Contents Revision History General Description Pin Function Descriptions Specifications Operating Conditions Absolute Maximum Ratings ESD Caution Package Marking Information Environmental Conditions Thermal Characteristics 208-LEAD MQFP Pin Configuration Outline Dimensions Ordering Guide
