Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 8
| Description | Low Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp |
| Pages / Page | 27 / 8 — ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. PIN CONFIGURATIONS AND … |
| Revision | I |
| File Format / Size | PDF / 1.1 Mb |
ADA4610-1/ADA4610-2/ADA4610-4. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. NIC. –IN. ADA4610-1 7 V+. +IN. TOP VIEW. OUT
ADA4610-1/ADA4610-2/ADA4610-4 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC 1 8 NIC –IN 2 ADA4610-1 7 V+ +IN 3 TOP VIEW 6 OUT (Not to Scale) V– 4 5 NIC
101
NOTES 1. NIC = NOT INTERNALLY CONNECTED.
09646- Figure 2. ADA4610-1 Pin Configuration, 8-Lead SOIC (R Suffix)
Table 6. ADA4610-1 P in Function Descriptions, 8-Lead SOIC Pin No. Mnemonic Description
1, 5, 8 NIC Not Internally Connected. 2 −IN Inverting Input. 3 +IN Noninverting Input. 4 V− Negative Supply Voltage. 6 OUT Output. 7 V+ Positive Supply Voltage.
OUT 1 5 V+ ADA4610-1 V– 2 TOP VIEW (Not to Scale) +IN 3 4 –IN
100 09646- Figure 3. ADA4610-1 Pin Configuration, 5-Lead SOT-23 (RJ Suffix)
Table 7. ADA4610-1 P in Function Descriptions, 5-Lead SOT-23 Pin No. Mnemonic Description
1 OUT Output. 2 V− Negative Supply Voltage. 3 +IN Noninverting Input. 4 −IN Inverting Input. 5 V+ Positive Supply Voltage. Rev. I | Page 8 of 27 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Applications Information Input Overvoltage Protection Peak Detector Current to Voltage (I to V) Conversion Applications Photodiode Circuits Comparator Operation Long-Term Drift Temperature Hysteresis Outline Dimensions Ordering Guide
