Datasheet VCNL3030X01 (Vishay) - 9
ManufacturerVishay
DescriptionFully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function
Pages / Page16 / 9 — VCNL3030X01. TABLE 1 - COMMAND CODE AND REGISTER DESCRIPTION. DATE BYTE. …
File Format / SizePDF / 271 Kb
VCNL3030X01. TABLE 1 - COMMAND CODE AND REGISTER DESCRIPTION. DATE BYTE. DEFAUL. COMMAND. REGISTER. R /. LOW /. FUNCTION DESCRIPTION
VCNL3030X01 TABLE 1 - COMMAND CODE AND REGISTER DESCRIPTION DATE BYTE DEFAUL COMMAND REGISTER R / LOW / FUNCTION DESCRIPTION
VCNL3030X01
TABLE 1 - COMMAND CODE AND REGISTER DESCRIPTION DATE BYTE DEFAUL COMMAND REGISTER R / LOW / T FUNCTION DESCRIPTION CODE NAME W HIGH VALUE
L Reserved R / W 0x01 Reserved 0x00 H Reserved R / W 0x01 Reserved L Reserved R / W 0x00 Reserved 0x01 H Reserved R / W 0x00 Reserved L Reserved R / W 0x00 Reserved 0x02 H Reserved R / W 0x00 Reserved L PS_CONF1 R / W 0x01 PS duty ratio, integration time, persistence, and PS enable / disable 0x03 H PS_CONF2 R / W 0x00 PS gain, PS output resolution, PS interrupt trigger L PS_CONF3 R / W 0x00 PS smart persistence, active force mode 0x04 H PS_MS R / W 0x00 LED current selection L PS_CANC_L R / W 0x00 PS cancellation level setting 0x05 H PS_CANC_M R / W 0x00 PS cancellation level setting L PS_THDL_L R / W 0x00 PS low interrupt threshold setting LSB byte 0x06 H PS_THDL_M R / W 0x00 PS low interrupt threshold setting MSB byte L PS_THDH_L R / W 0x00 PS high interrupt threshold setting LSB byte 0x07 H PS_THDH_M R / W 0x00 PS high interrupt threshold setting MSB byte L PS_Data_L R 0x00 PS LSB output data 0x08 H PS_Data_M R 0x00 PS MSB output data L Reserved R 0x00 Reserved 0x09 H Reserved R 0x00 Reserved L Reserved R 0x00 Reserved 0x0A H Reserved R 0x00 Reserved L Reserved R 0x00 Reserved 0x0B H Reserved R 0x00 Reserved L Reserved R 0x00 Reserved 0x0C H Reserved R 0x00 Reserved L Reserved R 0x00 Reserved 0x0D H INT_Flag R 0x00 PS interrupt flags, PS sunlight protection mode flag L ID_L R 0x80 Device ID LSB 0x0E For version with 0x41 as device address; 0x10 for version with 0x51, H ID_M R 0x00 0x20 for version with 0x40 and 0x30 for version with 0x60 as device address
Note
• All of reserved register are used for internal test. Please keep as default setting
Command Register Format
VCNL3030X01 provides an 8-bit command register for PS controlling. The description of each command format is shown in following tables.
TABLE 2 - REGISTER: PS_CONF1 DESCRIPTION REGISTER: PS_CONF1 COMMAND CODE: 0x03_L (0x03 DATA BYTE LOW)
Command Bit Description (0 : 0) = 1/40, (0 : 1) = 1/80, (1 : 0) = 1/160, (1 : 1) = 1/320 PS_Duty 7 : 6 PS IRED on / off duty ratio setting (0 : 0) = 1, (0 : 1) = 2, (1 : 0) = 3, (1 : 1) = 4 PS_PERS 5 : 4 PS interrupt persistence setting (0 : 0 : 0) = 1T, (0 : 0 : 1) = 1.5T, (0 : 1 : 0) = 2T, (0 : 1 : 1) = 2.5T, (1 : 0 : 0) = 3T, (1 : 0 : 1) = 3.5T, PS_ IT 3 : 1 (1 : 1 : 0) = 4T, (1 : 1 : 1) = 8T, PS integration time setting PS_SD 0 0 = PS power on, 1 = PS shut down, default = 1 Rev. 1.0, 12-Aug-2020
9
Document Number: 84960 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
