Datasheet NVH4L015N065SC1 (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionMOSFET -SiC Power, Single N-Channel, TO247-4L 650 V, 12 mW, 142 A
Pages / Page8 / 3 — NVH4L015N065SC1. ELECTRICAL CHARACTERISTICS. Parameter. Symbol. Test …
Revision2
File Format / SizePDF / 372 Kb
NVH4L015N065SC1. ELECTRICAL CHARACTERISTICS. Parameter. Symbol. Test Condition. Min. Typ. Max. Unit. SOURCE−DRAIN DIODE CHARACTERISTICS
NVH4L015N065SC1 ELECTRICAL CHARACTERISTICS Parameter Symbol Test Condition Min Typ Max Unit SOURCE−DRAIN DIODE CHARACTERISTICS
(TJ = 25°C unless otherwise specified) (continued)
Reverse Recovery Time tRR VGS = −5/18 V, ISD = 75 A, − 28 − ns dIS/dt = 1000 A/s Reverse Recovery Charge QRR − 234 − nC Reverse Recovery Energy EREC − 23 − J Peak Reverse Recovery Current IRRM − 16 − A Charge time Ta − 17 − ns Discharge time Tb − 11 − ns Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions.
www.onsemi.com 3
