Datasheet HMC-AUH232 (Analog Devices)
DescriptionGaAs HEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 43 GHz
Pages / Page10 / 1 — HMC-AUH232. GaAs HEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 43 GHz. …
File Format / SizePDF / 565 Kb
HMC-AUH232. GaAs HEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 43 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-AUH232 Analog Devices
HMC-AUH232
v02.0209
GaAs HEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 43 GHz Typical Applications Features
This HMC-AUH232 is ideal for: Small Signal Gain: 12 dB • 40 Gb/s Lithium Niobate/ Mach Zender Output Voltage: up to 8V pk-pk Fiber Optic Modulators Single-Ended I/Os • Broadband Gain Block for Test & Measurement High Speed Performance: 46 GHz 3 dB Bandwidth Equipment 4 Low Power Dissipation: 0.9 W • Broadband Gain Block for RF Applications Small Die Size: 2.1 x 1.70 x 0.1 mm • Military & Space IP
H The HMC-AUH232 is a GaAs MMIC HEMT Distributed Driver Amplifi er die which operates between DC and 43 GHz and provides a typical 3 dB bandwidth of S - C 46 GHz. The amplifi er provides 12 dB of small R signal gain while requiring only 180 mA from a +5V IE supply. The HMC-AUH232 exhibits very good gain IF and phase ripple to 40 GHz, and can output up to L 8V peak-to-peak with low jitter, making it ideal for use P in broadband wireless, fi ber optic communication and M test equipment applications. The amplifi er die occupies less than 3.6 mm2 which facilitates easy integration R A into Multi-Chip-Modules (MCMs). The HMC-AUH232 E requires external bias-tee as well as off-chip blocking IV components and bypass capacitors for the DC supply R lines. A gate voltage adjust, Vgg2 is provided for limited gain adjustment, while Vgg1 adjusts the bias L D current for the device. A IC T
Electrical Specifi cations*, T = +25 °C
P
A
Parameter Min. Typ. Max. Units Frequency Range DC - 43 GHz 0.5 - 5.0 GHz 12 14 dB E & O Small Signal Gain 35 - 45 GHz 10 12.5 dB V Input Return Loss 10 dB A Output Return Loss 8.5 dB W Supply Current 180 225 mA O 3 dB Bandwidth 43 46 GHz R Gain Ripple (5 to 35 GHz) ±0.6 ±1 dB IC 0.5 - 5.0 GHz ±14 ±20 ps M Group Delay Variation[1] 5 - 30 GHz ±10 ±11 ps 30 - 45 GHz ±22 ±25 ps Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
4 - 2
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
