Datasheet HMC-ALH216 (Analog Devices)
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 14 - 27 GHz
Pages / Page6 / 1 — HMC-ALH216. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 14 - 27 GHz. Typical …
File Format / SizePDF / 276 Kb
HMC-ALH216. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 14 - 27 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-ALH216 Analog Devices
HMC-ALH216
v03.0209
1
Typical Applications Features
This HMC-ALH216 is ideal for: Noise Figure: 2.5 dB @ 20 GHz IP • Point-to-Point Radios Gain: 18 dB H • Point-to-Multi-Point Radios P1dB Output Power: +14 dBm C • Military & Space Supply Voltage: +4V @ 90 mA - • Test Instrumentation Die Size: 2.25 x 1.58 x 0.1 mm RS IE IF L P M
A The HMC-ALH216 is a GaAs MMIC HEMT Wideband E Low Noise Amplifi er die which operates between 14 and 27 GHz. The amplifi er provides 18 dB of gain, IS 2.5 dB noise fi gure and +14 dBm of output power at O 1 dB gain compression while requiring only 90 mA N from a +4V supply voltage. The HMC-ALH216 amplifi er W is ideal for integration into Multi-Chip-Modules O (MCMs) due to its small size. L
Electrical Specifi cations*, T = +25° C, Vdd= +4V A
Parameter Min. Typ. Max. Units Frequency Range 14 - 27 GHz Gain 14 18 dB Gain Variation over Temperature 0.02 dB / °C Noise Figure 2.7 4.5 dB Input Return Loss 15 dB Output Return Loss 15 dB Supply Current (Idd) (Vdd = 4V, Vgg = -0.5 Typ.) 90 mA *Unless otherwise indicated, all measurements are from probed die Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 126
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
