Datasheet ADPA7006CHIP (Analog Devices) - 7
Description18 GHz to 44 GHz, GaAs, pHEMT, MMIC, 1/2 W Power Amplifier
Pages / Page24 / 7 — Data Sheet. ADPA7006CHIP. TYPICAL PERFORMANCE CHARACTERISTIC. S O. URN L. …
File Format / SizePDF / 465 Kb
Data Sheet. ADPA7006CHIP. TYPICAL PERFORMANCE CHARACTERISTIC. S O. URN L. S11. S21. AND RE. S22. +85°C. –10. +25°C. –55°C. –15. –20. –25
Data Sheet ADPA7006CHIP TYPICAL PERFORMANCE CHARACTERISTIC S O URN L S11 S21 AND RE S22 +85°C –10 +25°C –55°C –15 –20 –25
Data Sheet ADPA7006CHIP TYPICAL PERFORMANCE CHARACTERISTIC 30 30 25 28 ) 20 B 26 (d 15 S 24 S O 10 ) 22 B 5 d URN L ( T 20 0 IN S11 GA 18 –5 S21 AND RE S22 +85°C N 16 –10 +25°C AI –55°C G –15 14 –20 12 –25
0
10 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48
01
-013 6-
FREQUENCY (GHz)
186 018
FREQUENCY (GHz)
2 20 Figure 10. Gain and Return Loss vs. Frequency, VDD = 5 V, IDQ = 800 mA Figure 13. Gain vs. Frequency for Various Temperatures, VDD = 5 V, IDQ = 800 mA
30 30 28 28 26 26 24 24 ) 22 ) 22 B B d d ( 20 ( 20 IN IN GA 18 GA 18 5V 700mA 16 4V 16 800mA 900mA 14 14 12 12 10
1
10 18 20 22 24 26 28 30 32 34 36 38 40 42 44
1 -0
-014
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 11. Gain vs. Frequency for Various Supply Voltages (VDD), IDQ = 800 mA Figure 14. Gain vs. Frequency for Various IDQ Values, VDD = 5 V
0 0 +85°C 5V –5 –5 +25°C 4V B) –55°C B) (d (d S S –10 S S O –10 O L L –15 URN URN T T –15 RE RE UT –20 UT P P IN IN –20 –25 –25 –30 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-012
-015
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 12. Input Return Loss vs. Frequency for Various Temperatures, Figure 15. Input Return Loss vs. Frequency for Various Supply Voltages, V I DD = 5 V, IDQ = 800 mA DQ = 800 mA Rev. 0 | Page 7 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 28 GHz FREQUENCY RANGE 28 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING THE ADPA7006CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR THE ADPA7006CHIP VGGx AMR (ABSOLUTE MAXIMUM RATING) REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
