Datasheet HMC413QS16G, 413QS16GE (Analog Devices) - 6
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 1.6 - 2.2 GHz
Pages / Page8 / 6 — HMC413QS16G / 413QS16GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 1.6 - 2.2 …
File Format / SizePDF / 420 Kb
HMC413QS16G / 413QS16GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 1.6 - 2.2 GHz. Pin Descriptions. 11 - 55
HMC413QS16G / 413QS16GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 1.6 - 2.2 GHz Pin Descriptions 11 - 55
v04.0505
Pin Number Function Description Interface Schematic Ground: Backside of package has exposed metal ground slug that 1, 2, 4, 5, 7, 8, GND must be connected to ground thru a short path. Vias under the device 9, 10, 13, 15 are required. Power Control Pin. For maximum power, this pin should be connected 11 to 3.6V. For 5V operation, a dropping resistor is required. A higher 3, 14 Vpd1, Vpd2 voltage is not recommended. For lower idle current, this voltage can be reduced. T 6 RFIN This pin is AC coupled and matched to 50 Ohms from 1.6 to 2.2 GHz. - SM S R 11, 12 RFOUT RF output and bias for the output stage. IE IF L P Power supply voltage for the fi rst amplifi er stage. An external bypass 16 Vcc capacitor of 330 pF is required as shown in the application schematic. M R A E W O & P R A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 www.analog.com
11 - 55
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
