Datasheet MC14093B (ON Semiconductor) - 4
| Manufacturer | ON Semiconductor |
| Description | Quad 2-Input “NAND"Schmitt Trigger |
| Pages / Page | 9 / 4 — MC14093B. ELECTRICAL CHARACTERISTICS. −55. 125. VDD. Typ. Characteristic. … |
| Revision | 10 |
| File Format / Size | PDF / 190 Kb |
MC14093B. ELECTRICAL CHARACTERISTICS. −55. 125. VDD. Typ. Characteristic. Symbol. Vdc. Min. Max. Unit. http://onsemi.com
link to page 4 link to page 4 link to page 4
MC14093B ELECTRICAL CHARACTERISTICS
(Voltages Referenced to VSS)
−55
_
C 25
_
C 125
_
C VDD Typ Characteristic Symbol Vdc Min Max Min
(Note 2)
Max Min Max Unit
Output Voltage “0” Level VOL 5.0 − 0.05 − 0 0.05 − 0.05 Vdc Vin = VDD or 0 10 − 0.05 − 0 0.05 − 0.05 15 − 0.05 − 0 0.05 − 0.05 “1” Level VOH 5.0 4.95 − 4.95 5.0 − 4.95 − Vdc Vin = 0 or VDD 10 9.95 − 9.95 10 − 9.95 − 15 14.95 − 14.95 15 − 14.95 − Output Drive Current IOH mAdc (VOH = 2.5 Vdc) Source 5.0 –3.0 − –2.4 –4.2 − –1.7 − (VOH = 4.6 Vdc) 5.0 –0.64 − –0.51 –0.88 − –0.36 − (VOH = 9.5 Vdc) 10 –1.6 − –1.3 –2.25 − –0.9 − (VOH = 13.5 Vdc) 15 –4.2 − –3.4 –8.8 − –2.4 − (VOL = 0.4 Vdc) Sink IOL 5.0 0.64 − 0.51 0.88 − 0.36 − mAdc (VOL = 0.5 Vdc) 10 1.6 − 1.3 2.25 − 0.9 − (VOL = 1.5 Vdc) 15 4.2 − 3.4 8.8 − 2.4 − Input Current Iin 15 − ±0.1 − ±0.00001 ±0.1 − ±1.0 mAdc Input Capacitance Cin − − − − 5.0 7.5 − − pF (Vin = 0) Quiescent Current IDD 5.0 − 0.25 − 0.0005 0.25 − 7.5 mAdc (Per Package) 10 − 0.5 − 0.0010 0.5 − 15 15 − 1.0 − 0.0015 1.0 − 30 Total Supply Current (Notes 3 & 4) IT 5.0 IT = (1.2 mA/kHz) f + IDD mAdc (Dynamic plus Quiescent, 10 IT = (2.4 mA/kHz) f + IDD Per Package) 15 IT = (3.6 mA/kHz) f + IDD (CL = 50 pF on all outputs, all buffers switching) Hysteresis Voltage VH† 5.0 0.3 2.0 0.3 1.1 2.0 0.3 2.0 Vdc 10 1.2 3.4 1.2 1.7 3.4 1.2 3.4 15 1.6 5.0 1.6 2.1 5.0 1.6 5.0 Threshold Voltage Vdc Positive−Going VT+ 5.0 2.2 3.6 2.2 2.9 3.6 2.2 3.6 10 4.6 7.1 4.6 5.9 7.1 4.6 7.1 15 6.8 10.8 6.8 8.8 10.8 6.8 10.8 Negative−Going VT– 5.0 0.9 2.8 0.9 1.9 2.8 0.9 2.8 Vdc 10 2.5 5.2 2.5 3.9 5.2 2.5 5.2 15 4.0 7.4 4.0 5.8 7.4 4.0 7.4 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 2. Data labelled “Typ” is not to be used for design purposes but is intended as an indication of the IC’s potential performance. 3. The formulas given are for the typical characteristics only at 25_C. 4. To calculate total supply current at loads other than 50 pF: IT(CL) = IT(50 pF) + (CL – 50) Vfk where: IT is in mA (per package), CL in pF, V = (VDD – VSS) in volts, f in kHz is input frequency, and k = 0.004.
http://onsemi.com 3
