Datasheet ADG5436 (Analog Devices) - 3
DescriptionHigh Voltage Latch-Up Proof, Dual SPDT Switches
Pages / Page19 / 3 — Data Sheet. ADG5436. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
RevisionC
File Format / SizePDF / 498 Kb
Data Sheet. ADG5436. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C −40°C to +125°C Unit
Data Sheet ADG5436 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 4
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 9.8 Ω typ VS = ±10 V, IS = −10 mA; see Figure 25 11 14 16 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match 0.35 Ω typ VS = ±10 V , IS = −10 mA Between Channels, ∆RON 0.7 0.9 1.1 Ω max On-Resistance Flatness, RFLAT (ON) 1.2 Ω typ VS = ±10 V, IS = −10 mA 1.6 2 2.2 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = ±10 V, VD =  10 V; see Figure 28 ±0.25 ±0.75 ±6 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±10 V, VD =  10 V; see Figure 28 ±0.4 ±2 ±12 nA max Channel On Leakage, ID (On), IS (On) ±0.1 nA typ VS = VD = ±10 V; see Figure 24 ±0.4 ±2 ±12 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 170 ns typ RL = 300 Ω, CL = 35 pF 235 285 316 ns max VS = 10 V; see Figure 31 tON 173 ns typ RL = 300 Ω, CL = 35 pF 230 280 351 ns max VS = 10 V; see Figure 33 tOFF 124 ns typ RL = 300 Ω, CL = 35 pF 160 193 218 ns max VS = 10 V; see Figure 33 Break-Before-Make Time Delay, tD 55 ns typ RL = 300 Ω, CL = 35 pF 18 ns min VS1 = VS2 = 10 V; see Figure 32 Charge Injection, QINJ 200 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 34 Off Isolation −78 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Channel-to-Channel Crosstalk −58 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Total Harmonic Distortion + Noise 0.009 % typ RL = 1 kΩ, 15 V p-p, f = 20 Hz to 20 kHz; see Figure 29 −3 dB Bandwidth 102 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 30 Insertion Loss −0.7 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 CS (Off) 18 pF typ VS = 0 V, f = 1 MHz CD (Off) 62 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 83 pF typ VS = 0 V, f = 1 MHz Rev. C | Page 3 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE FOR SWITCHES TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
