Datasheet MAX912, MAX913 (Analog Devices) - 4
| Description | Single/Dual, Ultra-Fast, Low-Power, Precision TTL Comparators |
| Pages / Page | 11 / 4 — Single/Dual, Ultra-Fast, Low-Power Precision TTL Comparators. Typical … |
| File Format / Size | PDF / 1.1 Mb |
Single/Dual, Ultra-Fast, Low-Power Precision TTL Comparators. Typical Operating Characteristics. PROPAGATION DELAY
Single/Dual, Ultra-Fast, Low-Power Precision TTL Comparators Typical Operating Characteristics
(V+ = +5V, V- = -5V, VLE = 0V, CL = 15pF, TA = +25°C, unless otherwise noted.)
PROPAGATION DELAY PROPAGATION DELAY PROPAGATION DELAY vs. INPUT OVERDRIVE vs. SOURCE RESISTANCE vs. LOAD CAPACITANCE
10 20 14 V 18 VOD = 10mV OD = 10mV 12 9 MAX912/13 toc01 16 MAX912/13 toc02 MAX912/13 toc03 14 10 tPD- 8 12 8 10 tPD+ t t PD+ 6 PD+ 7 8 6 PROPAGATION DELAY (ns) PROPAGATION DELAY (ns) tPD- PROPAGATION DELAY (ns) 4 t 6 PD- 4 2
MAX912/MAX913
2 5 0 0 1 10 100 1 10 100 1k 10k 10 20 30 40 50 INPUT OVERDRIVE (mV) SOURCE RESISTANCE (Ω) LOAD CAPACITANCE (pF)
POSITIVE SUPPLY CURRENT NEGATIVE SUPPLY CURRENT PROPAGATION DELAY (PER COMPARATOR) (PER COMPARATOR) vs. TEMPERATURE vs. POSITIVE SUPPLY VOLTAGE vs. NEGATIVE SUPPLY VOLTAGE
11 10 1.4 T V A = +85°C OD = 5mV Q OUTPUT 9 V- = 0 TO 5V 10 tPD- 1.2 8 MAX912/13 toc04 MAX912/13 toc05 MAX912/13 toc06 TA = +85°C Q OUTPUT 7 9 1.0 T t A = +25°C PD- Q OUTPUT 6 t 8 PD+ 5 0.8 I+ (mA) I- (mA) TA = -40°C 4 TA = +25°C 7 T 0.6 3 A = -40°C PROPAGATION DELAY (ns) 2 6 0.4 Q OUTPUT 1 tPD+ 5 0 0.2 -40 -20 0 20 40 60 80 3 4 5 6 7 0 1 2 3 4 5 6 7 TEMPERATURE (°C) V+ (V) V- (V)
OFFSET VOLTAGE INPUT BIAS CURRENT OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. DIFFERENTIAL INPUT VOLTAGE
600 3.0 5 500 2.5 MAX912/13 toc07 MAX912/13 toc08 4 MAX912/13 toc09 µA) µV) 400 2.0 VCM = -5.2V 3 300 1.5 2 200 1.0 OFFSET VOLTAGE ( OUTPUT VOLTAGE (V) INPUT BIAS CURRENT ( VCM = 0V 1 100 0.5 VCM = 3.5V 0 0 0 -40 -20 0 20 40 60 80 -40 -20 0 20 40 60 80 -3 -2 -1 0 1 2 3 TEMPERATURE (°C) TEMPERATURE (°C) DIFFERENTIAL INPUT VOLTAGE (mV)
4 _______________________________________________________________________________________
