Datasheet MC33023, MC34023 (ON Semiconductor) - 5
ManufacturerON Semiconductor
DescriptionHigh Speed Single-Ended PWM Controller
Pages / Page19 / 5 — MC34023, MC33023. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. …
MC34023, MC33023. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. CURRENT SENSE SECTION. OUTPUT SECTION
MC34023, MC33023 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit CURRENT SENSE SECTION OUTPUT SECTION
link to page 5
(VCC = 15 V, RT = 3.65 kW, CT = 1.0 nF, for typical values TA = +25°C, for min/max values TA is the operating ambient temperature range that applies [Note 3], unless otherwise noted.)
Input Bias Current (Pin 9(12) = 0 V to 4.0 V) IIB − − 15 mA Current Limit Comparator Input Offset Voltage (Pin 11(14) = 1.1 V) VIO − − 45 mV Current Limit Reference Input Common Mode Range (Pin 11(14)) TJ = +25°C VCMR 1.0 − 3.0 V Shutdown Comparator Threshold Vth 1.25 1.40 1.55 V Propagation Delay (Current Limit/Shutdown to Output, TJ = +25°C) tPLH(in/out) − 50 80 ns
OUTPUT SECTION
Output Voltage V Low State (ISink = 20 mA) VOL − 0.25 0.4 (ISink = 200 mA) − 1.2 2.2 High State (ISource = 20 mA) VOH 13 13.5 − (ISource = 200 mA) 12 13 − Output Voltage with UVLO Activated (VCC = 6.0 V, ISink = 0.5 mA) VOL(UVLO) − 0.25 1.0 V Output Leakage Current (VC = 20 V) IL − 100 500 mA Output Voltage Rise Time (CL = 1.0 nF, TJ = +25°C) tr − 30 60 ns Output Voltage Fall Time (CL = 1.0 nF, TJ = +25°C) tf − 30 60 ns
UNDERVOLTAGE LOCKOUT SECTION
Startup Threshold (VCC Increasing) Vth(on) 8.8 9.2 9.6 V UVLO Hysteresis Voltage (VCC Decreasing After Turn−On) VH 0.4 0.8 1.2 V
TOTAL DEVICE
Power Supply Current ICC mA Startup (VCC = 8.0 V) − 0.5 1.2 Operating − 20 30 3. Low duty cycle pulse techniques are used during test to maintain junction temperature as close to ambient as possible. Tlow = 0°C for MC34023 Thigh = +70°C for MC34023 = −40°C for MC33023 = +105°C for MC33023
http://onsemi.com 4
