Datasheet VTL5C3, VTL5C4 (PerkinElmer)
ManufacturerPerkinElmer
DescriptionLow Cost Axial Vactrols
Pages / Page26 / 1 — Low Cost Axial Vactrols. VTL5C3, 5C4. PACKAGE DIMENSIONS INCH (MM). …
File Format / SizePDF / 421 Kb
Low Cost Axial Vactrols. VTL5C3, 5C4. PACKAGE DIMENSIONS INCH (MM). PLASTIC POTTING CONTOUR NOT CONTROLLED. DESCRIPTION
Datasheet VTL5C3, VTL5C4 PerkinElmer
Low Cost Axial Vactrols VTL5C3, 5C4 PACKAGE DIMENSIONS INCH (MM) PLASTIC POTTING CONTOUR NOT CONTROLLED DESCRIPTION
VTL5C3 has a steep slope, good dynamic range, a very low temperature coefficient of resistance, and a smal light history memory. VTL5C4 features a very low “on” resistance, fast response time, with a smaller temperature coefficient of resistance than VTL5C1.
ABSOLUTE MAXIMUM RATINGS @ 25°C
Maximum Temperatures LED Forward Voltage Drop @ 20 mA: 2.0V (1.65V Typ.) Storage and Operating: –40°C to 75°C Cel Power: 175 mW Min. Isolation Voltage @ 70% Rel. Humidity: 2500 VRMS Derate above 30°C: 3.9 mW/°C Output Cel Capacitance: 5.0 pF LED Current: 40 mA
1
Derate above 30°C: 0.9 mA/°C Cel Voltage: 250V (VTL5C3), 50V (VTL5C4) LED Reverse Breakdown Voltage: 3.0 V Input - Output Coupling Capacitance: 0.5 pF
ELECTRO-OPTICAL CHARCTERISTICS @ 25°C
ON Resistance
2
Slope Dynamic Range Response Time
4
OFF
3
Part Material (Typ.) (Typ.) Dark Resistance Turn-on to Turn-off (Decay) Number Type Input current Adapted @ 10 sec. (Min.) R@ 0.5 mA R 63% Final R DARK ON to 100 kΩ ------------- (Typ.) R@ 5 mA ------------ (Typ.) (Max.) R@ 20 mA 1 mA 30 kΩ VTL5C3 3 10 mA 5 Ω 10 MΩ 20 75 db 2.5 ms 35 ms 40 mA 1.5 Ω 1 mA 1.2 kΩ VTL5C4 4 10 mA 125 Ω 400 MΩ 18.7 72 db 6.0 ms 1.5 sec 40 mA 75 Ω Refer to Specification Notes, page 41.
PerkinElmer Optoelectronics, 10900 Page Ave., St. Louis, MO 63132 USA Phone: 314-423-4900 Fax: 314-423-3956 Web: www.perkinelmer.com/opto
45
