Datasheet 3OZ CiTiceL (City Technology) - 2
ManufacturerCity Technology
Description3OZ Ozone Sensor
Pages / Page3 / 2 — 3OZ CiTiceL®. Product. Key Features & Benefits:. Robust, 3-Series …
File Format / SizePDF / 309 Kb
3OZ CiTiceL®. Product. Key Features & Benefits:. Robust, 3-Series packaging. Range of accessories available
3OZ CiTiceL® Product Key Features & Benefits: Robust, 3-Series packaging Range of accessories available
3OZ CiTiceL®
Ozone (O ) Gas Sensor 3 Product Code : AS004-J00
Product
Data Sheet
Range of accessories available Technical Specifications Product Dimensions MEASUREMENT Operating Principle
3-electrode electrochemical
Nominal Range
0-2 ppm O3
Maximum Overload
5 ppm O3
Filter
None
Sensitivity*
7.2 µA/ppm ± 20%
Response Time (T )* 90
<150 Seconds
Baseline Offset (clean air)*
<120 ppb equiequivalent
Zero Shift (+20°C to +40°C)
+36 ppb equivalent
Resolution
20 ppb (electronics dependant)
Repeatability
5% of signal
Output Linearity
Linear
ELECTRICAL Recommended Load Resistor
33 Ω
Bias Voltage
Not Required
MECHANICAL Weight
22 g
Orientation
Any
ENVIRONMENTAL Operating Temperature Range
-20°C to +50°C
Recommended Storage Temp
0°C to 20°C All dimensions in mm
Operating Pressure Range
Atmospheric ± 10% All tolerances ±0.15 mm unless otherwise stated
Operating Humidity Range
15 - 90% RH non-condensing
LIFETIME IMPORTANT NOTE: Long Term Sensitivity Drift
<4% signal loss / month
Expected Operating Life
Two years in air Soldering to the pin connections will seriously
Storage Life
6 months in CTL container damage the sensor and invalidate the warranty.
* Specifications are valid at 20°C, 50% RH and 1013 mBar, using City Technology recommended circuitry. Performance characteristics outline the performance of sensors supplied within the first 3 months. Output signal can drift below the lower limit over time.
Doc. Ref.: 3oz.indd ECN I 4849 Issue 6 Page 2 of 3 12th June 2017 The Right Sensor Can Save A Life Web:
www.citytech.com
Email:
sales@citytech.com
Call:
+44(0) 23 9228 8100
