Datasheet SFH6156 (Vishay) - 4
ManufacturerVishay
DescriptionOptocoupler, Phototransistor Output, High Reliability, 5300 V RMS
Pages / Page9 / 4 — SFH6156. CURRENT TRANSFER RATIO PARAMETER. TEST CONDITION. PART. SYMBOL. …
File Format / SizePDF / 174 Kb
SFH6156. CURRENT TRANSFER RATIO PARAMETER. TEST CONDITION. PART. SYMBOL. MIN. TYP. MAX. UNIT. SWITCHING CHARACTERISTICS. PARAMETER
SFH6156 CURRENT TRANSFER RATIO PARAMETER TEST CONDITION PART SYMBOL MIN TYP MAX UNIT SWITCHING CHARACTERISTICS PARAMETER
SFH6156
CURRENT TRANSFER RATIO PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT
SFH6156-1 CTR 40 - 80 % SFH6156-2 CTR 63 - 125 % IF = 10 mA, VCE = 5 V SFH6156-3 CTR 100 - 200 % SFH6156-4 CTR 160 - 320 % IC/IF SFH6156-1 CTR 13 30 - % SFH6156-2 CTR 22 45 - % IF = 1 mA, VCE = 5 V SFH6156-3 CTR 34 70 - % SFH6156-4 CTR 56 90 - %
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT NON-SATURATED
Turn-on time IF = 10 mA, VCC = 5 V, RL = 75 Ω ton - 3 - μs Rise time IF = 10 mA, VCC = 5 V, RL = 75 Ω tr - 2 - μs Turn-off time IF = 10 mA, VCC = 5 V, RL = 75 Ω toff - 2.3 - μs Fall time IF = 10 mA, VCC = 5 V, RL = 75 Ω tf - 2 - μs Cut-off frequency IF = 10 mA, VCC = 5 V, RL = 75 Ω fCO - 250 - kHz
SATURATED
IF = 20 mA SFH6156-1 ton - 3 - μs SFH6156-2 ton - 4.2 - μs Turn-on time IF = 10 mA SFH6156-3 ton - 4.2 - μs IF = 5 mA SFH6156-4 ton - 6 - μs IF = 20 mA SFH6156-1 tr - 2 - μs SFH6156-2 tr - 3 - μs Rise time IF = 10 mA SFH6156-3 tr - 3 - μs IF = 5 mA SFH6156-4 tr - 4 - μs IF = 20 mA SFH6156-1 toff - 18 - μs SFH6156-2 toff - 23 - μs Turn-off time IF = 10 mA SFH6156-3 toff - 23 - μs IF = 5 mA SFH6156-4 toff - 25 - μs IF = 20 mA SFH6156-1 tf - 11 - μs SFH6156-2 tf - 14 - μs Fall time IF = 10 mA SFH6156-3 tf - 14 - μs IF = 5 mA SFH6156-4 tf - 15 - μs Rev. 3.0, 15-Mar-2023
4
Document Number: 83671 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
