Datasheet IMX (Power Integrations)
ManufacturerPower Integrations
DescriptionOff-Line Zero Voltage Switching (ZVS) Flyback Switcher IC For Multi-Output Applications
Pages / Page36 / 1 — InnoMux2-EP. Product Highlights. VLED. Highly Integrated, Compact …
InnoMux2-EP. Product Highlights. VLED. Highly Integrated, Compact Footprint. VCV1. FWD. CDR1. BPS. CONTROL. VSENSE. IDRIVE. ISENSE. BPP. DIM1. DIM2
Datasheet IMX Power Integrations
InnoMux2-EP
Family Off-Line Zero Voltage Switching (ZVS) Flyback Switcher IC for Multi-Output Applications
Product Highlights VLED Highly Integrated, Compact Footprint VCV1
• Up to 3 independently regulated outputs using a single control er and transformer • Eliminates post regulators • Incorporates a multi-mode Quasi-Resonant Discontinuous Conduction Mode (DCM) and Continuous Conduction Mode (CCM) flyback control er, 650 V, 725 V, 750 V or 1700 V power switch,
D
secondary-side control and synchronous rectification driver
D V FWD SR GN CDR1 BPS VCV1 VLED InnoMux2-EP CONTROL VSENSE
• Integrated FluxLink™ feedback link eliminates optocouplers
IDRIVE
Primary Switch • Zero voltage switching (ZVS) using advanced SR FET control with
ISENSE
and Controller DCM only mode
S BPP
Secondary • Excel ent transient response: <±5% CV with 100% load step Control IC
DIM1 DIM2
• Outputs up to 200 V for CV and CC (LED drive) configurations PI-9725-071423 Figure 1. Typical Application with LED Driver. (IMX2353F (1700 V) does not
EcoSmart™ – Energy Efficient
support LED Driver) • PowiGaN™ technology enables >90% efficient power supplies • Designs easily meet global energy efficiency regulations
VCVHV
• Proprietary switching algorithm ensures high efficiency across load • Low dissipation al ows PCB cooling – no heat sinks required
VCV1 Advanced Protection / Safety Features
• Primary sensed output OVP • Open SR-FET gate detection • Hysteretic thermal shutdown • Input voltage monitor with accurate brown-in/brown-out and overvoltage protection
D D V FWD SR GN CDR1 BPS VCV1 VCVHV
• Overload protection for each output
InnoMux2-EP CONTROL FB1
• LED short / open protection Primary Switch
FBHV
and Controller
Full Safety and Regulatory Compliance7 S BPP
Secondary • Reinforced isolation Control IC
Optional
PI-9789a-031224
3.3 V uVCC
• Isolation voltage >4000 VAC • 100% production HIPOT tested Figure 2. Typical Application with Two Constant Voltages. • UL1577 isolation voltage 4000 VAC (max) and TUV (EN62368) • Enables designs required to meet class A performance criteria for
VCVHV
EN61000-4 suite of test standards, including EN61000-4-2, 4-3 (30 V/m), 4-4, 4-5, 4-6, 4-8 (100 A/m) and 4-9 (1000 A/m)
VCV2 Green Package
• Halogen free and RoHS compliant
VCV1 Applications
• High efficiency driver for monitors and TVs • Ideal for designs that need to meet Energy Star 8, CEC, and 2021/2023 EU labeling requirements • High efficiency multi-output power supplies for industrial, smart-
D D V FWD SR GN CDR1 CDR2 BPS VCV1 VCV2 VCVHV
meter and appliance applications
InnoMux2-EP CONTROL FB1 FB2
Primary Switch and Controller
FBHV S BPP
Secondary Control IC PI-9724-101923 Figure 3. Typical Application with Three Constant Voltages. Figure 4. Left - InnoMux2-EP in InSOP-24B Package. Middle - InnoMux2-EP in InSOP-T28D Package. Right - InnoMux2-EP in InSOP-T28G Package. www.power.com October 2024 This Product is Covered by Patents and/or Pending Patent Applications.
