Datasheet MAX6125, MAX6141, MAX6145, MAX6150, MAX6160 (Analog Devices) - 3
DescriptionSOT23, Low-Cost, Low-Dropout, 3-Terminal Voltage References
Pages / Page12 / 3 — Electrical Characteristics—MAX6145. PARAMETER. SYMBOL. CONDITIONS. MIN. …
Electrical Characteristics—MAX6145. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Electrical Characteristics—MAX6150
Electrical Characteristics—MAX6145 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Electrical Characteristics—MAX6150
MAX6125/MAX6141/ SOT23, Low-Cost, Low-Dropout, MAX6145/MAX6150/MAX6160 3-Terminal Voltage References
(VIN = 4.7V, IOUT = 0mA, TA = +25°C, unless otherwise noted.) (Note 1)
Supply Voltage VIN TA = TMIN to TMAX 4.7 12.6 V T Output Voltage V A = +25°C 4.455 4.500 4.545 OUT V TA = TMIN to TMAX 4.410 4.590 Output Voltage Temperature Coefficient TCVOUT TA = TMIN to TMAX 15 50 ppm/°C 0.1Hz to 10Hz 30 Output Voltage Noise en µVP-P 10Hz to 10kHz 800 Line Regulation ∆VOUT/∆VIN VIN = 4.7V to 12.6V, TA = TMIN to TMAX 2 50 µV/V I Load Regulation ∆V SOURCE = 0mA to 1mA 0.6 1.8 OUT/∆IOUT mV/mA ISINK = 0mA to 1mA 1.75 18 T Quiescent Supply Current I A = +25°C 79 105 Q µA TA = TMIN to TMAX 130 Change in Supply Current vs. Change in Input Voltage ∆IQ/∆VIN VIN = 4.7V to 12.6V 1.7 6 µA/V
(VIN = 5.2V, IOUT = 0mA, TA = +25°C, unless otherwise noted.) (Note 1)
Supply Voltage VIN TA = TMIN to TMAX 5.2 12.6 V T Output Voltage V A = +25°C 4.950 5.000 5.050 OUT V TA = TMIN to TMAX 4.900 5.100 Output Voltage Temperature Coefficient TCVOUT TA = TMIN to TMAX 15 50 ppm/°C 0.1Hz to 10Hz 35 Output Voltage Noise en µVP-P 10Hz to 10kHz 900 Line Regulation ∆VOUT/∆VIN VIN = 5.2V to 12.6V, TA = TMIN to TMAX 1 50 µV/V I Load Regulation ∆V SOURCE = 0mA to 1mA 0.65 2 OUT/∆IOUT mV/mA ISINK = 0mA to 1mA 1.9 20 T Quiescent Supply Current I A = +25°C 80 110 Q µA TA = TMIN to TMAX 145 Change in Supply Current vs. Change in Input Voltage ∆IQ/∆VIN VIN = 5.2V to 12.6V 1.7 6 µA/V www.maximintegrated.com Maxim Integrated │ 3
