Datasheet DS4303 (Analog Devices) - 8
| Description | Electronically Programmable Voltage Reference |
| Pages / Page | 8 / 8 — Electronically Programmable Voltage Reference. Layout Considerations. … |
| File Format / Size | PDF / 396 Kb |
Electronically Programmable Voltage Reference. Layout Considerations. Chip Topology. DS4303. Power-Supply Decoupling
Electronically Programmable Voltage Reference Layout Considerations Chip Topology
To prevent an inadvertent programming cycle from TRANSISTOR COUNT: 6001 occurring during power-up, minimize capacitive load- ing on the ADJ pin. A large capacitance on this pin SUBSTRATE CONNECTED TO GROUND could potentially hold ADJ in a low state long enough that a programming cycle is initiated.
DS4303 Power-Supply Decoupling Package Information
To achieve best results, it is highly recommended that For the latest package outline information, go to a decoupling capacitor is used on the IC power-supply
www.maxim-ic.com/DallasPackInfo.
pin. Typical values of decoupling capacitors are 0.01µF or 0.1µF. Use a high-quality, ceramic, surface-mount capacitor, and mount it as close as possible to the VCC and GND pins of the IC to minimize lead inductance.
Revision History
Pages changed at Rev1: 1 Title changes—all pages Maxim cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim product. No circuit patent licenses are implied. Maxim reserves the right to change the circuitry and specifications without notice at any time.
8 _____________________Maxim Integrated Products, 120 San Gabriel Drive, Sunnyvale, CA 94086 408-737-7600
© 2005 Maxim Integrated Products is a registered trademark of Maxim Integrated Products, Inc. is a registered trademark of Dallas Semiconductor Corporation.
