Datasheet MAX6012 (Analog Devices) - 10
| Description | Precision, Low-Power, Low-Dropout, SOT23-3 Voltage References |
| Pages / Page | 16 / 10 — MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Typical … |
| File Format / Size | PDF / 2.3 Mb |
MAX6012/MAX6021/MAX6025/. MAX6030/MAX6041/MAX6045/MAX6050. Typical Operating Characteristics (continued). MAX6012. MAX6050
(VIN = +5V for MAX6012/21/25/30/41/45, VIN = +5.5V for MAX6050; IOUT = 0; TA = +25°C; unless otherwise noted.) (Note 6)
MAX6012 MAX6050 POWER-SUPPLY REJECTION POWER-SUPPLY REJECTION SUPPLY CURRENT vs. FREQUENCY vs. FREQUENCY vs. INPUT VOLTAGE
100 100 40 VCC = 5.5V ±0.25V 38 VALID OVER SPECIFIED VIN (MIN) TO VIN (MAX) MAX6012-10 MAX16012-11 36 MAX6012-12 FOR EACH PART 10 10 34 32 30 1 1 PSR (mV/V) PSR (mV/V) 28 26 SUPPLY CURRENT (µA) 0.1 0.1 24 22 0.01 0.01 20 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M 2 4 6 8 10 12 14 FREQUENCY (Hz) FREQUENCY (Hz) INPUT VOLTAGE (V)
MAX6012 MAX6050 OUTPUT IMPEDANCE OUTPUT IMPEDANCE SUPPLY CURRENT vs. FREQUENCY vs. FREQUENCY vs. TEMPERATURE
1k 1k 40 MAX6012-13 MAX6012-14 MAX6012-15 ) Ω 100 Ω 100 35 VIN = 12.5V 10 10 30 VIN = 7.5V VIN = 5.5V OUTPUT IMPEDANCE ( 1 OUTPUT IMPEDANCE ( 1 SUPPLY CURRENT (µA) 25 VIN = 2.5V (MAX6012/MAX6025 ONLY) 0.1 0.1 20 0.01 0.1 1 10 100 1k 10k 100k 1M 0.01 0.1 1 10 100 1k 10k 100k 1M -40 -20 0 20 40 60 80 100 FREQUENCY (Hz) FREQUENCY (Hz) TEMPERATURE (°C)
MAX6012 MAX6050 MAX6012 0.1Hz TO 10Hz OUTPUT NOISE 0.1Hz TO 10Hz OUTPUT NOISE TURN-ON TRANSIENT
MAX6012-16 MAX6012-17 V MAX6012-18 IN 1V/div VOUT 10µV/div VOUT 20µV/div VOUT 1V/div 1sec/div 1sec/div 10µs/div www.analog.com Analog Devices │ 10
