Datasheet MAX6225, MAX6241, MAX6250 (Analog Devices)
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 1 — here. MAX6225/MAX6241/MAX6250. Low-Noise, Precision,. +2.5V/+4.096V/+5V …
here. MAX6225/MAX6241/MAX6250. Low-Noise, Precision,. +2.5V/+4.096V/+5V Voltage References. General Description. Features
Datasheet MAX6225, MAX6241, MAX6250 Analog Devices
link to page 1 Click
here
for production status of specific part numbers.
MAX6225/MAX6241/MAX6250 Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage References General Description Features
The MAX6225/MAX6241/MAX6250 are low-noise, ● Low 1.0ppm/°C Temperature Coefficient precision voltage references with extremely low 1ppm/°C ● Very Low 1.5μVP-P Noise (0.1Hz to 10Hz) temperature coefficients and excellent ±0.02% initial ● ±0.02% Initial Accuracy accuracy. These devices feature buried-zener technology ● ±15mA Output Source and Sink Current for lowest noise performance. Load-regulation specifications ● Low, 18mW Power Consumption (MAX6225) are guaranteed for source and sink currents up to 15mA. ● Industry-Standard Pinout Excellent line and load regulation and low output impedance ● Optional Noise Reduction and Voltage Trim at high frequency make them ideal for high-resolution data-conversion systems up to 16 bits. ● Excellent Transient Response ● 8-Pin SO Package Available The MAX6225 is set for 2.500V output, the MAX6241 is ● Low 20ppm/1000h Long-Term Stability set for 4.096V output, and the MAX6250 is set for 5.000V ● Stable for All Capacitive Loads output. All three devices provide for the option of external trimming and noise reduction.
Ordering Information Applications MAX PART TEMPERATURE PIN- TEMPCO
● High-Resolution Analog-to-Digital and Digital-to-
RANGE PACKAGE (ppm/°C)
Analog Converters MAX6225ACPA+ 0°C to +70°C 8 Plastic DIP 2.0 ● High-Accuracy Reference Standard MAX6225BCPA+ 0°C to +70°C 8 Plastic DIP 5.0 ● High-Accuracy Industrial and Process Control MAX6225ACSA+ 0°C to +70°C 8 SO 2.0 MAX6225BCSA+ 0°C to +70°C 8 SO 5.0 ● Digital Voltmeters MAX6225AEPA+ -40°C to +85°C 8 Plastic DIP 3.0 ● ATE Equipment MAX6225BEPA+ -40°C to +85°C 8 Plastic DIP 7.0 ● Precision Current Sources MAX6225AESA+ -40°C to +85°C 8 SO 5.0 MAX6225BESA+ -40°C to +85°C 8 SO 7.0 MAX6225AMJA -55°C to +125°C 8 CERDIP 5.0 MAX6225BMJA -55°C to +125°C 8 CERDIP 8.0 +Denotes a lead(Pb)-free/RoHS-compliant package.
Ordering Information continues at end of data sheet. Typical Operating Circuit Pin Configuration
8V TO 36V INPUT TOP VIEW
IN REFERENCE OUT I.C. 1 8 I.C. OUT
MAX6225
IN 2
MAX6225
7 I.C. 2.2µF*
MAX6241 MAX6241 MAX6250
NR 3
MAX6250
6 OUT NR TRIM 2.2µF* GND GND 4 5 TRIM
DIP/SO
*OPTIONAL I.C. = INTERNALLY CONNECTED; DO NOT USE 19-1139; Rev 6; 7/19
