Datasheet MAX6225, MAX6241, MAX6250 (Analog Devices) - 5
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 5 — Electrical Characteristics—MAX6250. PARAMETER. SYMBOL. CONDITIONS. MIN. …
Electrical Characteristics—MAX6250. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:. Note 2:. Note 3:. Note 4:
Electrical Characteristics—MAX6250 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Note 1: Note 2: Note 3: Note 4:
MAX6225/MAX6241/MAX6250 Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN C, E, M 8 36 V MAX6250A +25°C 4.999 5.000 5.001 Output Voltage VOUT MAX6250B +25°C 4.995 5.000 5.005 V MAX6250AC_A C 1.0 2.0 MAX6250AE_A E 1.5 3.0 Output Voltage Temperature MAX6250AMJA M 2.0 5.0 Coefficient (Note 1) TCVOUT MAX6250BC_A C 2.5 5.0 ppm/°C MAX6250BE_A E 2.5 7.0 MAX6250BMJA M 2.5 8.0 +25°C 10 18 C 30 8V ≤ VIN ≤ 10V E 35 M 45 Line Regulation (Note 2) ΔVOUT / ΔVIN +25°C 2 5 ppm/V C 7 10V ≤ VIN ≤ 36V E 8 M 10 C 1 6 Sourcing: 0mA ≤ IOUT ≤ 15mA E 1 7 M 3 9 Load Regulation (Note 2) ΔVOUT / ΔIOUT C 1 6 ppm/mA Sinking: -15mA ≤ IOUT ≤ 0mA E 1 7 M 6 15 +25µC 2.0 3.0 Supply Current IIN C, E, M 3.3 mA Trim-Adjustment Range ΔVOUT Figure 1 C, E, M ±30 ±50 mV Turn-On Settling Time tON To ±0.01% of final value +25°C 10 µs 0.1Hz ≤ f ≤ 10Hz +25°C 3.0 µVp-p Output Noise Voltage (Note 3) en 10Hz ≤ f ≤ 1kHz +25°C 2.5 5.0 µVRMS Temperature Hysteresis (Note 4) +25°C 20 ppm Long-Term Stability ΔVOUT / t +25°C 20 ppm/ 1000h
Note 1:
Temperature coefficient is measured by the box method; i.e., the maximum ∆VOUT is divided by ∆T x VOUT.
Note 2:
Line regulation (∆VOUT / (VOUT x ∆VIN)) and load regulation (∆VOUT/(VOUT x ∆IOUT)) are measured with pulses and do not include output voltage changes due to die-temperature changes.
Note 3:
Noise specifications are 100% tested for the 10Hz to 1kHz bandwidth. Contact factory for 100% noise testing in the 0.1Hz to 10Hz bandwidth.
Note 4:
Temperature hysteresis is specified at TA = +25°C by measuring VOUT before and after changing temperature by +25°C using the PDIP package. www.maximintegrated.com Maxim Integrated │ 5
