Datasheet MAX6190, MAX6191, MAX6192, MAX6193, MAX6194, MAX6195, MAX6198 (Analog Devices) - 7
| Description | Precision, Micropower, Low-Dropout Voltage References |
| Pages / Page | 14 / 7 — MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage … |
| File Format / Size | PDF / 264 Kb |
MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage References. ELECTRICAL CHARACTERISTICS—MAX6195. PARAMETER
MAX6190–MAX6195/MAX6198 Precision, Micropower, Low-Dropout Voltage References ELECTRICAL CHARACTERISTICS—MAX6195
(VIN = 5.5V, IOUT = 0nA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT INPUT
MAX6195A 4.998 5.000 5.002 Output Voltage VOUT TA = +25°C MAX6195B 4.995 5.000 5.005 V MAX6195C 4.990 5.000 5.010 MAX6195A 2 5 Output-Voltage Temperature TCVOUT MAX6195B 4 10 ppm/°C Coefficient (Note 1) MAX6195C 8 25 ΔVOUT/ Line Regulation (VOUT + 0.2V) ≤ VIN ≤ 12.6V 25 160 µV/V ΔVIN ΔV Sourcing: 0 OUT/ ≤ IOUT ≤ 500µA 0.17 0.85 Load Regulation µV/µA ΔIOUT Sinking: -500µA ≤ IOUT ≤ 0 0.24 1.10 Dropout Voltage (Note 4) VIN - VOUT ΔVOUT ≤ 0.2%, IOUT = 500µA 100 200 mA Short to GND 4 Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ΔVOUT/ 75 ppm (Note 2) cycle ΔVOUT/ ppm/ Long-Term Stability 1000hrs at +25°C 50 time 1000hrs
DYNAMIC
0.1Hz to 10Hz 120 µVP-P Noise Voltage eOUT 10Hz to 10kHz 240 µVRMS Ripple Rejection VOUT/VIN VIN = 5.5V ±100mV, f = 120Hz 72 dB Turn-On Settling Time tR To 0.1%, COUT = 50pF 220 µs Capacitive-Load Stability Range COUT (Note 3) 0 2.2 nF
INPUT OUTPUT
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 35 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 0.8 2 µA/V Maxim Integrated 7
