Datasheet VOFD341A (Vishay) - 4
ManufacturerVishay
Description3 A Output Current IGBT and MOSFET Driver
Pages / Page12 / 4 — VOFD341A. TEST CIRCUITS. SWITCHING CHARACTERISTICS. PARAMETER. TEST …
File Format / SizePDF / 225 Kb
VOFD341A. TEST CIRCUITS. SWITCHING CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. Note
VOFD341A TEST CIRCUITS SWITCHING CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT Note
VOFD341A
TEST CIRCUITS
1 6 1 6 0.1 µF I = 7 mA 0.1 µF F to 16 mA IF + V = 15 V 2 5 + V CC 2 5 CC V > 5 V to 30 V V > 5 V O O 3 4 3 4 Shield Shield Fig. 1 - IFLH Test Circuit Fig. 2 - UVLO Test Circuit
(Tamb = 25 °C, VCC - VEE = 30 V unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Propagation delay time to VO = “low” tPHL 50 - 200 ns Propagation delay time to VO = “high” Rg = 10 Ω, Cg = 15 nF, tPLH 50 - 200 ns f = 20 kHz, duty cycle = 50 %, Pulse width distortion PWD - 10 70 ns IF = 7 mA to 16 mA, Propagation delay difference (1) V PDD -100 - 100 ns CC = 15 V to 30 V, Output rise time (10 % to 90 %) VEE = ground tr - 35 - ns Output fall time (90 % to 10 %) tf - 35 - ns
Note
(1) The difference between tPHL and tPLH between any two parts, series parts, or channels under same test conditions 1 6 I 0.1 µF F + VCC t t V > 5 V r f O I V F 2 5 OH 90 % Rg VO 50 % Cg 10 % 3 4 VOL Shield t t PLH PHL Fig. 3 - tPLH, tPHL, tr and tf Test Circuit and Waveforms
COMMON MODE TRANSIENT IMMUNITY
Common mode transient immunity at IF = 10 mA to 16 mA, |CM high level output (V H| 35 50 - kV/μs O = “high”) (1) VCM = 1500 V, VCC = 30 V Common mode transient immunity at VF = 0 V, VCM = 1500 V, |CM low level output (V L| 35 50 - kV/μs O = “low”) (2) VCC = 30 V
Notes
(1) CMH is the maximum rate of rise of the common mode voltage that can be sustained with the output voltage in the logic high state (VO > 15 V) (2) CML is the maximum rate of fall of the common mode voltage that can be sustained with the output voltage in the logic low state (VO < 1 V) Rev. 1.0, 20-Jun-2024
4
Document Number: 80420 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
