Datasheet FDC604P (Fairchild) - 5
ManufacturerFairchild
DescriptionP-Channel 1.8V Specified PowerTrench MOSFET
Pages / Page8 / 5 — SuperSOTTM-6 Tape and Reel Data and Package Dimensions. SSOT-6 Packaging …
File Format / SizePDF / 377 Kb
SuperSOTTM-6 Tape and Reel Data and Package Dimensions. SSOT-6 Packaging Configuration:. Packaging Description:. 631
SuperSOTTM-6 Tape and Reel Data and Package Dimensions SSOT-6 Packaging Configuration: Packaging Description: 631
Figur e 1.0
Customize Lab el SSOT-6 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film, adhesive layer, sealant, and anti-static sprayed agent. These reeled parts in standard option are shipped with Anti static Cover Tape 3,000 units per 7" or 177cm diameter reel. The reels are dark blue in color and is made of polystyrene plastic (anti- static coated). Other option comes in 10,000 units per 13" or 330cm diameter reel. This and some other options are described in the Packaging Information table. These full reels are individually barcode labeled and placed inside a pizza box (illustrated in figure 1.0) made of recyclable corrugated brown paper with a Fairchild logo printing. One pizza box contains three reels maximum. And these pizza boxes are placed inside a barcode labeled shipping box which comes in different sizes depending on the number of parts shipped. F63TNR Embo ssed Label Carrier Tape
631 631 631 631 631 SSOT-6 Packaging Information Pin 1
Standard
Packaging Option
D87Z (no f l ow c ode )
Packaging type
TNR TNR
SSOT-6 Unit Orientation Qty per Reel/Tube/Bag
3,000 10,000
Reel Size
7" Dia 13"
Box Dimension (mm)
184x187x47 343x343x64
Max qty per Box
9,000 30,000
Weight per unit (gm)
0.0158 0.0158 343mm x 342mm x 64mm F63TNR Labe l
Weight per Reel (kg)
0.1440 0.4700 Intermediate bo x fo r D87Z Option
Note/Comments
F63TNR Label F63TNR Labe l sa mpl e F63TNR 184mm x 187mm x 47mm Label LOT: CBVK741B019 QTY: 3000 Pizza Box fo r Standar d Opti on FSID: FDC633N SPEC:
SSOT-6 Tape Leader and Trailer
D/C1: D9842 QTY1: SPEC REV: D/C2: QTY2: CPN: N/F: F (F63TNR)3
Configuration:
Figur e 2.0 Carrier Tape Comp onent s Cover Tape Traile r Tape Lead er Tape 300mm mi nimum or 500mm mi nimum or 75 empty poc kets 125 emp ty poc kets 1998 Fairchild Semiconductor Corporation August 1999, Rev. C
