Datasheet OPA206, OPA2206, OPA4206 (Texas Instruments) - 5
| Manufacturer | Texas Instruments |
| Description | Input-overvoltage-protected, low-power, low-noise four-channel op amp with super-beta inputs |
| Pages / Page | 48 / 5 — OPA206. , OPA2206. , OPA4206. www.ti.com. 5 Specifications 5.1 Absolute … |
| File Format / Size | PDF / 3.3 Mb |
OPA206. , OPA2206. , OPA4206. www.ti.com. 5 Specifications 5.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 5.2 ESD Ratings. VALUE
link to page 5 link to page 5 link to page 5 link to page 5
OPA206 , OPA2206 , OPA4206 www.ti.com
SBOSA11E – MARCH 2020 – REVISED DECEMBER 2023
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
Single supply 40 VS Supply voltage, VS = (V+) – (V–) V Dual supply ±20 Signal input pin voltage (V–) – 40 (V+) + 40 V Output short-circuit(2) Continuous TA Operating temperature –40 150 °C TJ Junction temperature 150 °C TSTG Storage temperature, Tstg –65 150 °C (1) Operation outside the Absolute Maximum Ratings may cause permanent device damage. Absolute Maximum Ratings do not imply functional operation of the device at these or any other conditions beyond those listed under Recommended Operating Conditions. If used outside the Recommended Operating Conditions but within the Absolute Maximum Ratings, the device may not be fully functional, and this may affect device reliability, functionality, performance, and shorten the device lifetime. (2) Short-circuit to ground, one amplifier per package.
5.2 ESD Ratings VALUE UNIT
Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±2000 V(ESD) Electrostatic discharge V Charged-device model (CDM), per JANSI/ESDA/JEDEC JS-002(2) ±1000 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
5.3 Recommended Operating Conditions
MIN NOM MAX UNIT
Single supply 4.5 36 VS Supply voltage, VS = (V+) – (V–) V Dual supply ±2.25 ±18 TA Operating temperature –40 125 °C Copyright © 2023 Texas Instruments Incorporated Submit Document Feedback 5 Product Folder Links: OPA206 OPA2206 OPA4206 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information: OPA206 5.5 Thermal Information: OPA2206 5.6 Thermal Information: OPA4206 5.7 Electrical Characteristics: VS = ±5 V 5.8 Electrical Characteristics: VS = ±15 V 5.9 Typical Characteristics 6 Parameter Measurement Information 6.1 Typical Specifications and Distributions 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Input Overvoltage Protection 7.3.2 Input Offset Trimming 7.3.3 Lower Input Bias With Super-Beta Inputs 7.3.4 Overload Power Limiter 7.3.5 EMI Rejection 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 Voltage Attenuator 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 Discrete, Two-Op-Amp Instrumentation Amplifier 8.2.3 Input Buffer and Protection for ADC Driver 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Device Support 9.1.1 Development Support 9.1.1.1 PSpice® for TI 9.2 Documentation Support 9.2.1 Related Documentation 9.3 Receiving Notification of Documentation Updates 9.4 Support Resources 9.5 Trademarks 9.6 Electrostatic Discharge Caution 9.7 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
