Datasheet MAX4480, MAX4481, MAX4482, MAX4483 (Analog Devices)
DescriptionSingle/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
Pages / Page10 / 1 — EVALUATION KIT AVAILABLE. MAX4480–MAX4483. Single/Dual/Quad, Low-Cost, …
EVALUATION KIT AVAILABLE. MAX4480–MAX4483. Single/Dual/Quad, Low-Cost, Single-Supply,. Rail-to-Rail Op Amps with Shutdown
Datasheet MAX4480, MAX4481, MAX4482, MAX4483 Analog Devices
EVALUATION KIT AVAILABLE MAX4480–MAX4483 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown General Description Features
The MAX4480–MAX4483 low-cost, general-purpose op ● Single +2.5V to +5.5V Supply Voltage Range amps offer rail-to-rail outputs, draw only 50μA of quies- ● 50μA Quiescent Current per Amplifier cent current, and operate from a single +2.5V to +5.5V ● 0.5μA (max) Shutdown Mode (MAX4481) supply. For additional power conservation, the MAX4481 ● Available in Space-Saving Packages offers a low-power shutdown mode that reduces supply • 5-Pin SC70 (MAX4480) current to 0.5μA (max) and puts the amplifier’s output in • 6-Pin SC70 (MAX4481) a high-impedance state. These devices are unity-gain • 8-Pin SOT23 (MAX4482) stable with capacitive loads up to 400pF. The MAX4480– ● 105dB AVOL with 5kΩ Load MAX4483 are specified to +125°C, making them suitable ● 0.005% THD with 100kΩ Load for use in a variety of harsh environments. ● Rail-to-Rail Output Voltage Swing The MAX4480 is a single amplifier offered in a tiny 5-pin ● 3.0mA of Sink and Source Load Current SC70 package. The MAX4481 is a single amplifier with a low-power shutdown mode that reduces supply current ● Unity-Gain Stable up to CLOAD = 400pF to < 0.5μA and comes in a 6-pin SC70 package. The
Ordering Information
MAX4482 is a dual amplifier and comes in the space-sav- ing 8-pin SOT23 or μMAX® package. The MAX4483 is a
PART TEMP RANGE PIN- TOP
quad amplifier and comes in a 14-pin TSSOP package.
PACKAGE MARK
All devices are specified for operation across the -40°C to
MAX4480
AXK+T -40°C to +125°C 5 SC70 ABU +125°C automotive temperature range. MAX4480AUK+T -40°C to +125°C 5 SOT23 ADPJ
Applications MAX4481
AXT+T -40°C to +125°C 6 SC70 AAN ● Single-Supply Zero-Crossing Detectors MAX4481AUT+T -40°C to +125°C 6 SOT23 AAOS ● Instruments and Terminals MAX4481MXT/PR3+ -55°C to +110°C 6 SC70 AEE ● Portable Communications
MAX4482
AKA+T -40°C to +125°C 8 SOT23 AAEJ ● Electronic Ignition Modules ● Infrared Receivers MAX4482ASA+ -40°C to +125°C 8 SO — ● Sensor Signal Detection MAX4482AUA+ -40°C to +125°C 8 FMAX —
MAX4483
ASD+ -40°C to +125°C 14 SO —
Selector Guide
MAX4483AUD+ -40°C to +125°C 14 TSSOP —
SHUTDOWN
+Denotes a lead(Pb)-free/RoHS-compliant package.
PART NO. OF AMPLIFIERS PER PACKAGE MODE
T = Tape and reel. MAX4480 1 No
Pin Configurations
MAX4481 1 Yes
MAX4480 MAX4481
MAX4482 2 No
IN+ 1 5 V IN+ 1 6 V MAX4483 4 No DD DD VSS 2 VSS 2 5 SHDN IN- 3 4 OUT IN- 3 4 OUT
SC70-5/SOT23-5 SC70-6/SOT23-6
μMAX is a registered trademark of Maxim Integrated Products, Inc.
Pin Configurations continued at end of data sheet.
19-1809; Rev 4; 5/14
