Datasheet MAX4480, MAX4481, MAX4482, MAX4483 (Analog Devices) - 5
| Description | Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown |
| Pages / Page | 10 / 5 — Typical Operating Characteristics (continued). OUTPUT VOLTAGE SWING LOW. … |
| File Format / Size | PDF / 2.4 Mb |
Typical Operating Characteristics (continued). OUTPUT VOLTAGE SWING LOW. COMMON-MODE REJECTION RATIO. LARGE-SIGNAL GAIN
MAX4480–MAX4483 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
(VDD = +5V, VSS = 0V, VCM = VDD/2, VSHDN = 5V, RL ≥ 1MΩ connected to VDD/2, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE SWING LOW COMMON-MODE REJECTION RATIO LARGE-SIGNAL GAIN vs. TEMPERATURE vs. TEMPERATURE vs. OUTPUT VOLTAGE
11 -80 130 R R L = 5kΩ to VDD/2 L = 5kΩ to VDD/2 125 10 MAX4480 toc10 -82 MAX4480 toc11 120 MAX4480 toc12 9 115 -84 110 (mV) 8 SS 105 - V 7 CMRR (dB) GAIN (dB) -86 100 V OUT 6 95 -88 90 5 85 4 -90 80 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 TEMPERATURE (°C) TEMPERATURE (°C) VOUT (V)
LARGE-SIGNAL GAIN MINIMUM OPERATING VOLTAGE TOTAL HARMONIC DISTORTION vs. TEMPERATURE vs. TEMPERATURE PLUS NOISE vs. FREQUENCY
110 2.0 100 RL = 5kΩ to VDD/2 1.9 RL = 5kΩ VOUT = 2VP-P MAX4480 toc13 1.8 MAX4480 toc14 MAX4480 toc15 10 AV = +1 105 1.7 BW = 30kHz 1.6 1 100 (MIN) 1.5 GAIN (dB) V DD 1.4 THD + N (%) 0.1 1.3 95 1.2 0.01 1.1 90 1.0 0.001 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 10 100 1k 10k 100k TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz)
TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY PLUS NOISE vs. INPUT AMPLITUDE PLUS NOISE vs. INPUT AMPLITUDE
100 100 100 RL = 100kΩ RL = 5kΩ RL = 100kΩ VOUT = 2VP-P f = 1kHz f = 1kHz MAX4480 toc16 10 AV = +1 10 MAX4480 toc17 BW = 22kHz 10 MAX4480 toc18 BW = 22kHz BW = 30kHz 1 1 1 THD + N (%) 0.1 THD + N (%) 0.1 THD + N (%) 0.1 0.01 0.01 0.01 0.001 0.001 0.001 10 100 1k 10k 100k 0 1 2 3 0 0.5 1.0 1.5 2.0 2.5 3.0 FREQUENCY (Hz) VIN (Vp-p) VIN (Vp-p) www.maximintegrated.com Maxim Integrated │ 5
