Datasheet MAX4480, MAX4481, MAX4482, MAX4483 (Analog Devices) - 6
| Description | Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown |
| Pages / Page | 10 / 6 — Typical Operating Characteristics (continued). NONINVERTING SMALL-SIGNAL. … |
| File Format / Size | PDF / 2.4 Mb |
Typical Operating Characteristics (continued). NONINVERTING SMALL-SIGNAL. CAPACITIVE-LOAD STABILITY. TRANSIENT RESPONSE
MAX4480–MAX4483 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
(VDD = +5V, VSS = 0V, VCM = VDD/2, VSHDN = 5V, RL ≥ 1MΩ connected to VDD/2, TA = +25°C, unless otherwise noted.)
NONINVERTING SMALL-SIGNAL CAPACITIVE-LOAD STABILITY TRANSIENT RESPONSE
20 AV = +1V/V TA = +25°C RL // CL MAX4480 toc19 MAX4480 roc20 15 IN UNSTABLE REGION 10 AV = 1V/V RL = 5kΩ 50mV/div 5 CAPACITIVE LOAD (nF) STABLE REGION OUT 0 1k 10k 100k 20µs/div RESISTIVE LOAD (Ω)
NONINVERTING LARGE-SIGNAL PERCENT OVERSHOOT TRANSIENT RESPONSE vs. CAPACITIVE LOAD
25 POSITIVE MAX4480 roc21 20 MAX4480 toc22 IN OVERSHOOT 15 1V/div 10 OVERSHOOT (%) 5 NEGATIVE OUT OVERSHOOT AV = 1V/V RL = 5kΩ 0 0 100 200 300 400 500 600 100µs/div CLOAD (pF)
CHANNEL-TO-CHANNEL ISOLATION vs. FREQUENCY SUPPLY CURRENT vs. SUPPLY VOLTAGE
120 60 110 VOUT = VDD/2 100 50 MAX4480 toc23 MAX4480 toc24 90 40 80 70 30 60 50 20 SUPPLY CURRENT (mA) 40 10 CHANNEL-TO-CHANNEL ISOLATION (dB) 30 20 0 10 100 1k 10k 100k 1M 0 1 2 3 4 5 6 FREQUENCY (kHz) SUPPLY VOLTAGE (V) www.maximintegrated.com Maxim Integrated │ 6
