Datasheet MAX931, MAX932, MAX933, MAX934 (Analog Devices) - 4
DescriptionUltra-Low-Power, Low-Cost Comparators with 2% Reference
Pages / Page16 / 4 — Ultra Low-Power, Low-Cost Comparators with 2% Reference. ELECTRICAL …
File Format / SizePDF / 168 Kb
Ultra Low-Power, Low-Cost Comparators with 2% Reference. ELECTRICAL CHARACTERISTICS—3V Operation (continued). PARAMETER
Ultra Low-Power, Low-Cost Comparators with 2% Reference ELECTRICAL CHARACTERISTICS—3V Operation (continued) PARAMETER
(V+ = 3V, V- = GND = 0V, TA = TMIN to TMAX, unless otherwise noted.)
PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Common-Mode Voltage Range V- V+ – 1.3 V Common-Mode Rejection Ratio V- to (V+ – 1.3V) 0.2 1 mV/V Power-Supply Rejection Ratio V+ = 2.5V to 11V 0.1 1 mV/V Voltage Noise 100Hz to 100kHz 20 µVRMS Hysteresis Input Voltage Range MAX931, MAX932, MAX933 REF – 0.05 REF V Overdrive = 10mV 14 Response Time TA = +25°C, 100pF load µs Overdrive = 100mV 5 Output High Voltage C/E temp. ranges, IOUT = 10mA V+ – 0.4 V
MAX931-MAX934
MAX932, V- + 0.4 MAX933 Output Low Voltage C/E temp. ranges, IOUT = 0.8mA V MAX931 GND + 0.4
REFERENCE
C temp. range 1.158 1.182 1.206 Reference Voltage V E temp. range 1.147 1.217 TA = +25°C 15 25 Source Current µA C/E temp. ranges 6 TA = +25°C 8 15 Sink Current µA C/E temp. ranges 4 Voltage Noise 100Hz to 100kHz 100 µVRMS
4 _______________________________________________________________________________________
