Datasheet MAX931, MAX932, MAX933, MAX934 (Analog Devices) - 5
| Description | Ultra-Low-Power, Low-Cost Comparators with 2% Reference |
| Pages / Page | 16 / 5 — Ultra Low-Power, Low-Cost. Comparators with 2% Reference. MAX931-MAX934 |
| File Format / Size | PDF / 168 Kb |
Ultra Low-Power, Low-Cost Comparators with 2% Reference MAX931-MAX934 __________________________________________Typical Operating Characteristics
(V+ = 5V, V- = GND, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE LOW OUTPUT VOLTAGE HIGH vs. REFERENCE OUTPUT VOLTAGE vs. vs. LOAD CURRENT LOAD CURRENT OUTPUT LOAD CURRENT
2.5 5.0 1.190 V+ = 5V V+ = 5V SINK 4.5 1.185 MAX921/4-TOC1 2.0 MAX921/924-TOC2 MAX921/924-TOC3 4.0 1.180 V+ = 3V SOURCE 1.5 3.5 1.175 (V) (V) OLV OHV 1.0 3.0 1.170 2.5 1.165 V+ = 3V 0.5 V+ = 5V 2.0 REFERENCE OUTPUT VOLTAGE (V) 1.160 OR V+ = 3V 0.0 1.5 1.155 0 4 8 12 16 20 0 10 20 30 40 50 0 5 10 15 20 25 30 LOAD CURRENT (mA) LOAD CURRENT (mA) OUTPUT LOAD CURRENT (µA)
REFERENCE VOLTAGE MAX931 MAX932 vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE
1.22 4.5 5.0 IN+ = IN- + 100mV 1.21 IN+ = IN- +100mV 4.5 MAX921/924-TOC4 EXTENDED TEMP. RANGE 4.0 MAX921/924-TOC5 MAX921/924-TOC6 1.20 µA) µA) 4.0 1.19 COMMERCIAL V+ = 5V, V- = - 5V TEMP. RANGE 3.5 V+ = 5V, V- = 0V 1.18 3.5 3.0 1.17 V+ = 3V, V- = 0V 3.0 SUPPLY CURRENT ( SUPPLY CURRENT ( REFERENCE VOLTAGE (V) 1.16 2.5 2.5 1.15 V+ = 5V, V- = 0V V+ = 3V, V- = 0V 2.0 1.14 2.0 -60 -20 20 60 100 140 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -20 20 60 100 140 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX934 MAX933 MAX934 SUPPLY CURRENT vs. SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE LOW SUPPLY VOLTAGES
5.0 10 10 IN+ = (IN- + 100mV) IN+ = IN- +100mV IN+ = IN- +100mV 9 4.5 MAX921/924-TOC7 MAX921/924-TOC8 MAX921/924-TOC9 µA) µA) 8 µA) 4.0 1 V+ = 5V, V- = 0V 7 V+ = 5V, V- = -5V 3.5 6 3.0 0.1 V+ = 5V, V- = 0V SUPPLY CURRENT ( SUPPLY CURRENT ( 5 SUPPLY CURRENT ( 2.5 4 V+ = 3V, V- = 0V V+ = 3V, V- = 0V 2.0 3 0.01 -60 -20 20 60 100 140 -60 -20 20 60 100 140 1.0 1.5 2.0 2.5 TEMPERATURE (°C) TEMPERATURE (°C) SINGLE-SUPPLY VOLTAGE (V)
_______________________________________________________________________________________ 5
