Datasheet MAX5436, MAX5437, MAX5438, MAX5439 (Analog Devices) - 2
Description±15V, 128-Tap, Low-Drift Digital Potentiometers
Pages / Page11 / 2 — ±15V, 128-Tap, Low-Drift Digital Potentiometers. ABSOLUTE MAXIMUM …
File Format / SizePDF / 248 Kb
±15V, 128-Tap, Low-Drift Digital Potentiometers. ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS. MAX5436–MAX5439
±15V, 128-Tap, Low-Drift Digital Potentiometers ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS MAX5436–MAX5439
VDD to GND, VSS = GND..-0.3V to +34V Continuous Power Dissipation (TA = +70°C) VSS to GND, VDD = GND..-34V to +0.3V 10-Pin µMAX (derate 6.94mW/°C above +70°C) ...556mW VDD to VSS ..-0.3V to +34V 14-Pin TSSOP (derate 9.1mW/°C above +70°C) ...727mW VDD to VCC ..-6.3V to +28.75V Operating Temperature Range ...-40°C to +85°C VCC to VSS ..-0.3V to +34V Junction Temperature ..+150°C VCC to GND ..-0.3V to +6V Storage Temperature Range ...-65°C to +150°C DIN, SCLK, CS, SHDN ...-0.3V to (VCC + 0.3V) Lead Temperature (soldering, 10s) ...+300°C H, L, W, IN+, IN-, OUT ...(VSS - 0.3V) to (VDD + 0.3V) Maximum Continuous Current into H, L, and W MAX5436–MAX5439...±1mA Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(VDD = +15V, VSS = -15V, VCC = +5V, VH = VDD, VL = VSS, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C, unless otherwise noted.)
MAX5436–MAX5439 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DC PERFORMANCE (voltage-divider mode)
Resolution 2N 128 Taps Integral Nonlinearity INL (Note 1) ±1 LSB Differential Nonlinearity DNL (Note 1) ±1 LSB End-to-End Resistor Tempco TCR 35 ppm/°C Ratiometric Resistor Tempco 5 ppm/°C Full-Scale Error RHL = 50kΩ (MAX5436/MAX5437) -0.3 LSB Zero-Scale Error RHL = 50kΩ (MAX5436/MAX5437) +0.3 LSB Full-Scale Error RHL = 100kΩ (MAX5438/MAX5439) -0.15 LSB Zero-Scale Error RHL = 100kΩ (MAX5438/MAX5439) +0.15 LSB
DC PERFORMANCE (variable-resistor mode)
Resolution 2N 128 Taps Integral Nonlinearity INL (Note 2) ±1 LSB Differential Nonlinearity DNL (Note 2) ±1 LSB
DC PERFORMANCE (resistor characteristics)
Wiper Resistance WR (Note 3) 0.9 2 kΩ Wiper Capacitance WC Midscale 6 pF MAX5438/MAX5439 75 100 125 End-to-End Resistance RHL kΩ MAX5436/MAX5437 37.5 50 62.5
DIGITAL INPUTS
Input High Voltage VCC = 4.75V to 5.25V (Note 4) 2.4 V Input Low Voltage VCC = 4.75V to 5.25V 0.8 V
2 _______________________________________________________________________________________
