Datasheet VS-26MT, VS-36MT (Vishay)
ManufacturerVishay
DescriptionThree Phase Bridge Rectifier, 25 A to 35 A
Pages / Page7 / 1 — VS-26MT.., VS-36MT.. Series. Three Phase Bridge Rectifier, 25 A, 35 A. …
File Format / SizePDF / 178 Kb
VS-26MT.., VS-36MT.. Series. Three Phase Bridge Rectifier, 25 A, 35 A. FEATURES. D-63. PRIMARY CHARACTERISTICS. DESCRIPTION
Datasheet VS-26MT, VS-36MT Vishay
Three Phase Bridge Rectifier, 25 A, 35 A FEATURES
• Universal, 3 way terminals: push-on, wrap around or solder • High thermal conductivity package, electrically insulated case • Center hole fixing • Excellent power/volume ratio • UL E300359 approved • Nickel plated terminals solderable using lead (Pb)-free solder; solder alloy Sn/Ag/Cu (SAC305); solder
D-63
temperature 260 °C to 275 °C • Designed and qualified for industrial and consumer level • Material categorization: for definitions of compliance
please see www.vishay.com/doc?99912 IO 25 A, 35 A V
DESCRIPTION
RRM 50 V to 1600 V Package D-63 A range of extremely compact, encapsulated three phase Circuit configuration Three phase bridge bridge rectifiers offering efficient and reliable operation. They are intended for use in general purpose and instrumentation applications.
MAJOR RATINGS AND CHARACTERISTICS VALUES VALUES SYMBOL CHARACTERISTICS UNITS 26MT.. 36MT..
25 35 A IO TC 70 60 °C 50 Hz 360 475 IFSM A 60 Hz 375 500 50 Hz 635 1130 I2t A2s 60 Hz 580 1030 VRRM 50 to 1600 V TJ -55 to +150 °C
ELECTRICAL SPECIFICATIONS VOLTAGE RATINGS V V I VOLTAGE RRM, MAXIMUM REPETITIVE RSM, MAXIMUM NON-REPETITIVE RRM MAXIMUM TYPE NUMBER PEAK REVERSE VOLTAGE PEAK REVERSE VOLTAGE AT T CODE J MAXIMUM V V mA
05 50 75 10 100 150 20 200 275 40 400 500 VS-26MT.. 60 600 725 2 VS-36MT.. 80 800 900 100 1000 1100 120 1200 1300 140 1400 1500 160 1600 1700 Revision: 15-Jan-2019
1
Document Number: 93565 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
