Datasheet NV6288 (Navitas Semiconductor) - 4
ManufacturerNavitas Semiconductor
DescriptionGaNSense Motor Drive IC in Half-Bridge Configuration
Pages / Page34 / 4 — NV6288. 7. Specifications. 7.1. Absolute Maximum Ratings (1) (with …
File Format / SizePDF / 2.5 Mb
NV6288. 7. Specifications. 7.1. Absolute Maximum Ratings (1) (with respect to PGND unless noted). SYMBOL. PARAMETER. MAX. UNITS
NV6288 7 Specifications 7.1 Absolute Maximum Ratings (1) (with respect to PGND unless noted) SYMBOL PARAMETER MAX UNITS
NV6288 7. Specifications 7.1. Absolute Maximum Ratings (1) (with respect to PGND unless noted) SYMBOL PARAMETER MAX UNITS
VIN HV input 0 to +650 V VSW(CONT) Switch Node Continuous Voltage Rating -7 to +657 V V (2) SW(TRAN) Switch Node Transient Voltage Rating -10 to +800 V IDSL @ TC=100ºC Continuous Output Current (Low-side FET) 8.6 A IDSL PULSE@ TC=25ºC Pulsed Output Current (Low-side FET) 17.2 A IDSH @ TC=100ºC Continuous Output Current (High-side FET) 8.6 A IDSH PULSE@ TC=25ºC Pulsed Output Current (High-side FET) 17.2 A VB (to VSW) High-side Gate Driver Bootstrap Rail 30 V RDDH (to VSW) Hi-Side Turn-On dV/dt Setting Pin -0.3 to VB V RSSH (to VSW) Hi-Side Turn-Off dV/dt Setting Pin -0.3 to 5.3 V V Supply Voltage 30 V CC RDDL Low-Side Turn-On DV/DT Setting Pin -0.3 to VCC V RSSL Low-Side Turn-Off DV/DT Setting Pin -0.3 to 5.3 V VFLT/EN FLT/EN Pin Voltage -0.3 to VCC V IFLT/EN FLT/EN Pull-Up Current 5m A V PWM Input Pin Voltages -0.6 to +20 or V INH, VINL CC V V CS Pin Voltage -0.3 to 5.3 V CS ICSP External Current Sense Positive Input Voltage -0.3 to 5.3 V ICSN External Current Sense Negative Input Voltage -0.3 to 5.3 V dV/dt (3) Slew Rate ±200 V/ns T Junction Temperature -55 to 150 ºC J T Storage Temperature -55 to 150 ºC STOR (1) Absolute maximum ratings are stress ratings; devices subjected to stresses beyond these ratings may cause permanent damage. (2) VDS (TRAN) rating allows for surge ratings during non-repetitive events that are <100us (for example start-up, line interruption). VDS (TRAN) rating allows for repetitive events that are <300ns, with 80% derating required (for example repetitive leakage inductance spikes). (3) Max dV/dt rating is based on stress ratings and common mode transient immunity
Final Datasheet 4 Rev Apr. 29, 2025
